I need a fuel injector pressure regulator for a 96' ford f-350 7.3 turbo diesel part number 800-427. I have looked online and found nothing and none of my local part stores carry it or even get it. Any ideas? This truck has been sitting since thanksgiving. Thanks
Try sending an email to Ed (FTE Parts Guy). He's a member here and an OEM parts supplier with good pricing. Here's his website but send him an email under his "contact us" tab. Good luck.
Welcome to FTE. You missed the section you wanted by just a hair. This is the 99-03 diesel section. The one right below this is the one you're looking for. We'll get this thread moved down there for you. In the mean time, you can contact Ed (FTE Parts Guy) and he can get you a price on your FPR. Click here
Is your HPOP not building pressure? Are you using a scanner or gauge to read pressures? Before replacing the IPR I'd at least take it apart, clean it up and put on a new set of o-rings.
