vibration @ 2k & up
Old Jan 29, 2009 | 04:29 PM
84-250's Avatar
84-250
vibration @ 2k & up
revving the engine in neutral, there is a vibration that starts getting noticeable around 2k rpms. Around 3k the truck is shaking pretty good. As far as I know the injectors have 184k on them, the dmfw has been replaced with a valair smfw awhile back. Its a 94.5 so I cant run a contribution test or buzz test(that I know of). I've had the truck not vibrate before doing the same test.
Ideas?
Old Jan 30, 2009 | 04:56 AM
84-250's Avatar
84-250
I was thinking of getting the pcm flashed so I can get OBD2. Then get the scangauge from aeroforce or joey to run some tests.
Old Jan 30, 2009 | 05:44 AM
scatgo's Avatar
scatgo
I have a 94.5 that I used a OBD2 code reader on before. Do you know for sure you need to get the PCM reflashed?
Old Jan 30, 2009 | 06:46 PM
84-250's Avatar
84-250
I dont know for sure if I need the reflash.
Old Mar 9, 2009 | 05:45 PM
84-250's Avatar
84-250
any other ideas?
1300rpms physically shakes shifter, slow but hard
calms down at 1500
at 2000, shifter buzzes/rattles
increases in volume/frequency all the way till redline.
feel the vib in the seat also.
trying to setup a time to meet with dzljim to run AE soon.
Old Mar 9, 2009 | 05:54 PM
Cuda_jim's Avatar
Cuda_jim
Stick shift??? DMF clutch will do that when it's on it's way out.
Old Mar 9, 2009 | 06:21 PM
84-250's Avatar
84-250
nope, valair smfw
Old Mar 9, 2009 | 08:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
perhaps only running on 7 cylinders? you'd be surprised how well these trucks run on a weak injector or a dead one for that matter
Old Mar 10, 2009 | 04:11 PM
84-250's Avatar
84-250
Does anyone make bellowed uppipes for the OBS yet? I think one is seeping, Drv side upper. Leakage just means less boost and less power,correct. Does it effect mileage also?.
Old Mar 10, 2009 | 04:17 PM
Cuda_jim's Avatar
Cuda_jim
Originally Posted by 84-250
nope, valair smfw
Sorry about that, I'm going back to reading school Wasn't even drinking when I missed that... doooohh!
