Key won't turn.
Old Mar 8, 2009 | 08:30 PM
otter712's Avatar
otter712
Key won't turn.
I Have a 98 Explorer and the key will not turn at all even tried turning the steering wheel with no luck. The theft light keeps blinking on the dash but I just got the vehicle and only drove it once so I'm not sure if that is normal. Any ideals???????
Old Mar 9, 2009 | 08:11 AM
marragtop's Avatar
marragtop
Try moving the shifting lever and turn the key at the same time. Also, is it parked on a hill?
Old Mar 9, 2009 | 11:01 PM
texan2004's Avatar
texan2004
Might also try some WD 40 in the lock cylinder. Could be nothing more than a stuck tumbler in the lock. I've had this problem with my door locks but not the ignition. Not to say it couldn't be the problem her though. Cheap enough and easy enough to find out.
Good luck. Sorry to hear you are having the problem.
Old Mar 9, 2009 | 11:13 PM
AzBlueWolf's Avatar
AzBlueWolf
are the wheels turned? up against the curb?
you may really have to turn the wheel hard...
jhoopman86
1978 - 1996 Big Bronco
Aug 4, 2010 09:30 AM
CsChuck14
Jan 17, 2007 07:49 PM
nyunicorn
Dec 15, 2003 06:40 PM
lerry
Jul 6, 2001 11:11 AM
