Timing marks for my IP...
Old Mar 9, 2009 | 07:48 PM
1dieselman's Avatar
1dieselman
Maybe when your "buddy" tried to start it something happened to them or the relay. Do you hear the relay coming on? Maybe check the fusible links
Old Mar 9, 2009 | 08:22 PM
KyleG's Avatar
KyleG
Yea I had a problem with them some time back, so the controller is bypassed and I have them wired to a button in the truck and It has worked fine for a while now so i dont know what is wrong with the thing.
Old Mar 9, 2009 | 08:38 PM
starmilt's Avatar
starmilt
Did the reflection off a butterknife work.
Old Mar 10, 2009 | 07:32 AM
fonefiddy's Avatar
fonefiddy
Originally Posted by KyleG
How do I know if I am on my TDC exhaust stroke or TDC compression stroke? I got the scribe line on the harmonic balencer right, and the "y" marks lined up and felt for the compression stroke. and the truck just turns and turns, not even a sputter. I get a fog of unburnt out the stacks, thats it. The only thing else I can think of is that some how my glowplugs stopped workin too. but idk?
Your prolly 180 degrees off. Usually they'll fire and run when 180 off.
I posted a link for the way to get the IP gear back on properly. Did You follow the directions?
Pull all of the Gp's, stuff a piece of plastic down the #1 GP Hole, turn the engine over with the crank bolt until the plastic pops out. Your on the compression stroke. Now align the timing mark. It's not the mark with the timing probe holder.
Vanzal15
Jul 23, 2013 01:36 PM
daleyboy
Mar 18, 2013 10:53 AM
TheDocta
24
Jul 16, 2010 08:09 PM
dani9678
Nov 19, 2004 09:07 AM
