Timing marks for my IP...
Old Mar 8, 2009 | 11:19 AM
KyleG's Avatar
KyleG
Exclamation Timing marks for my IP...
Hey guys, well here it is, I had my injection pump off, along with my upper timing gear cover to re-seal it since it leaked a little oil. And my very very dumb buddy hopped in the truck when i wasnt there and tried to fire it up!
So as you can imagine I have no idea where my timing is at. So i am asking if there is a way to line my cam timing mark back at 12'oclock so my injection pump will be in time when I place that gear back in. Is there any marks on the crank pulley or harmonic balencer anywhere that i can go by?
Old Mar 8, 2009 | 11:34 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
that sucks
Old Mar 8, 2009 | 11:48 AM
1dieselman's Avatar
1dieselman
Pull the glow plug out of #1 cylinder, roll the engine with your buddies finger over GP hole, your looking for TDC on the compression stroke and scribe line on damper will be at TDC. You should be able to see the Y on the cam gear (very tough to see), Your IP gear should go in with dowel hole at 4 o'clock position. Make sure the Ys are together silicone the cam gear cover and install and then shoot your buddy. Something else, the cam gear is supposed to have red makings on the teeth on each side of the Y but it's not very often that you can actually see it.
Old Mar 8, 2009 | 07:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you slide something like a butter knife between the timing gear cover and the cam timing gear, you may be able to see the reflection of the Y.
I never tried it, but an attempt to see it is better than pulling the front of the motor off to see the marks.
Someone here posted that did work for them.
After you get it back together, you know where the butter knife goes, right?
Old Mar 8, 2009 | 10:21 PM
starmilt's Avatar
starmilt
Seems like that butterknife would hurt.
Old Mar 8, 2009 | 10:29 PM
Lead_Pusher's Avatar
Lead_Pusher
If someone did that to mine a butter knife would be the least of their worries. You could always force his head in between the cover and gear so he could see the timing marks. That is if you let him within 100' of your truck.
Old Mar 8, 2009 | 11:07 PM
Dave Sponaugle
Sharp knife wounds heal to fast.
Dull knife that rips it's way through takes much longer to heal.
When you do this, you have to make sure you are at TDC on the compression stroke, if you are the Y should be TDC on the cam gear.
If you are at TDC exhaust stroke, no Y there to see.
Old Mar 8, 2009 | 11:11 PM
starmilt's Avatar
starmilt
Is it because the knife might lose some of it's shine that you need to get tdc first.
Old Mar 8, 2009 | 11:44 PM
Dave Sponaugle
The space between the timing gear cover and the cam gear is very tight.
You almost have to bow the timing gear cover to see the timing mark in the shiney knife surface.
The cam gear does not come all the way to the top of the timing gear cover plate.
So you have to see the front side of the gear below tooth level on a gear down inside the engine.
TDC is the only time the mark will be top dead center of the cam gear.
So now you are left to figure out TDC exhaust or TDC compression stroke.
Old Mar 9, 2009 | 12:16 AM
starmilt's Avatar
starmilt
Yea but you need a shiny blade for this so don't stick your buddy until you have it timed.
Thats what I was talking about.
Old Mar 9, 2009 | 07:26 AM
KyleG's Avatar
KyleG
ha ha okay thanks guys, yea I gave him a lot of crap for this one.
Old Mar 9, 2009 | 07:51 AM
fonefiddy's Avatar
fonefiddy
Here ya go.
Good Luck.
Oilburners.net
Old Mar 9, 2009 | 07:26 PM
KyleG's Avatar
KyleG
How do I know if I am on my TDC exhaust stroke or TDC compression stroke? I got the scribe line on the harmonic balencer right, and the "y" marks lined up and felt for the compression stroke. and the truck just turns and turns, not even a sputter. I get a fog of unburnt out the stacks, thats it. The only thing else I can think of is that some how my glowplugs stopped workin too. but idk?
Old Mar 9, 2009 | 07:32 PM
1dieselman's Avatar
1dieselman
Pull the #1 GP when it pushes your finger off the hole its coming up on compression. Then pull the cover plate for the three IP gear bolts the dowel should be at 4 o'clock when your scribe mark on harmonic balancer is on TDC
Old Mar 9, 2009 | 07:42 PM
KyleG's Avatar
KyleG
Thats exactly where its at now and I still have no start up. not even any sputters, I have a feeling somethin is wrong with my GPs
