Bed crane installation.
Old Mar 7, 2009 | 10:21 PM
DaveWilliams's Avatar
DaveWilliams
Has anyone ever tried to install a bed crane? I got one at Harbor Freight and it looks like a straightforward install, but it says to attatch it to the frame. Well the frame does't exactly sit where all of the pictures show the crane to be typically installed......and besides that, I need it directly behind the wheel well so I can lift in and out the generator. Does anyone happen to have one of these things installed and possibly some pictures of how they reinforced the underside of the bed? I am working with a fabricator on getting some 3/8 inch plate bolted to the bottom and some tubing run down to the hitch frame. Anyone have any other suggestions with pictures? Thanks, Dave
Old Mar 8, 2009 | 01:57 AM
twags6's Avatar
twags6
I'd get a nice thick plate like they use for gooseneck hitches, put it in between the bed and frame if possible. Extend it out past one side of the frame and bolt the crane to that. Anything heavy enough to bend a 3/8 or 1/2 inch plate would most likely break the crane itself
Old Mar 8, 2009 | 03:04 AM
orng1's Avatar
orng1
I bought one of those yrs ago but never installed it. I bought it for my Ranger, I was always hauling motors.
Old Mar 8, 2009 | 03:38 AM
ron's power stroke's Avatar
ron's power stroke
me and a friend built one from an old telescopic wrecker boom with a 5000 lb electric winch..it locks right onto his gooseneck ball for easy install and can be taken right back out...works awesome..
Old Mar 8, 2009 | 06:25 AM
DaveWilliams
That would be awesome to be able to mount it to the fifth wheel hitch. It may wobble around but that would be nice. Thanks for the input...I appreicate all suggestions...Dave
Old Mar 8, 2009 | 08:11 PM
farmdad's Avatar
farmdad
Ron, now you have me thinking. I have a BW ball hitch on my F350. I could make a post that would fit into the socket that the ball goes into and have an easy-in, easy-out crane mount. The arm would have to be a little long to clear the tailgate and possibly have a trolley on the jib but it would sure beat lifting heavy items. Would have to be careful how much weight is lifted so I wouldn't twist the ball mount. Sounds like a project for next winter.
Old Mar 9, 2009 | 08:19 AM
bearman113's Avatar
bearman113
Alaska Chapter ******
A guy I know has a lift installed in the bed of his F150 to lift his wheelchair in and out of the bed. I'll run him down in the next couple of days and find out the particulars for you.
Old Mar 9, 2009 | 06:38 PM
DaveWilliams
Thanks a bunch I appreciate any suggestions....Dave
Old Mar 10, 2009 | 12:06 PM
bronco252's Avatar
bronco252
Dave,
I have one of those from Harbor Freight and I use it so I can move my generator from my shop to my house without having to have any help. You most definitely need to reinforce the bottom of the bed. I designed a a bracket to bolt in the bed and use a bolt hole from the tie down point. I'll see if I can find my drawings and I'll post them for you. My set up is completely bolt on with the exception of drilling the holes through the bed. I have it set up so I can leave the bracket in place and remove that ugly orange thing from my bed. It only takes about 5 minutes to bolt the hoist bracket back in and be ready to work.
Old Mar 10, 2009 | 08:29 PM
bronco252's Avatar
bronco252
Dave,
I added a photo album called bed crane so you can see what I did. Sorry about the dirty truck haven't had the time to clean it. I've had that bracket in there for about 4 years now and it works out very well for me since I don't like that hoist's ugly post. I did have to flatten the bed in the area of the bracket. I found my drawing that I did to have it made but it's in paper form so I'll have to get it scanned if you're interested. Hope this helps....
Mark
Old Mar 10, 2009 | 08:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
That is CRUEL!
Old Mar 12, 2009 | 12:37 PM
bronco252's Avatar
bronco252
Dave,
I added the drawing I made for the bracket into the photo album.
Gary Lewis
1535
Jan 9, 2017 12:13 PM
Herb Brooks
6.4L Power Stroke Diesel
37
May 31, 2016 05:41 PM
71dusterdan
Garage & Workshop
22
May 30, 2016 04:34 PM
porthole
6.7L Power Stroke Diesel
18
Jun 5, 2015 10:02 AM
frankc
Aftermarket Products
Jan 2, 2006 03:30 PM
