ok guys heres the scoop, i couldnt find any write-up of how to do this, where to or how deep to cut into my pedistal to delete the ebpv actuator. as some of you know my brothers turbo went out, sooooo i figured i would remove the ebpv actuator which makes the remove/install a breeze. i found a couple of pics in tim's web shots, and it gave me an idea of what i was looking for..
and heres how i did it,
after i got the pedistal off the turbo, i removed the guts of the actuator
here i used a vertical bandsaw to take the actuator off. note 2 holes have to be plug welded as well as the main oil passage. i used an aluminum grinding wheel on a 4.5" grinder to make everything smoothe.
another view
I used a piece of 3/4" aluminum pipe and mitered it to cover up the big "hole". the reason was i was worried about oil flow. i wanted to keep it as unrestricted as possible, as well as leaving enough clearance for the 2 bolts in the back..
aluminum pipe i used
finished product!
i was a nervous wreck with the band saw. i was afraid i was gonna cut too deep so i just took little bites. hopefully this can help someone who is interested in doing this. i put a few bolts connecting the pedistal to the turbo and set it on the engine. i had no problems starting either bolt facing the firewall with my hand. if theres any questions fire away
Excelent work with the band saw and welding. very good pics and write up. reps sent.
I want to ask what is for the bolt that was there originally and was remove and welded the hole that was left.
thanks for the props guys. its not that often i can work on my truck (usually im working on others, just like this ). id love to do some other custom stuff but time never allows me.
jose are you talking about the very first pic with the (rod about 9/16") sicking straight up?? if so the rod is where the solenoid sits. the best way i can explain, is picture an ipr with the solenoid sitting on it, remove the solenoid. same principle, it contacts through the metal. i hope this makes sense
jdap, the actuator controls the ebpv and is seperate
dirk, just like jose said, when you go to take your turbo off, youll see where clearance is everything concerning the last 2 pedistal bolts. with the actuator out of the way,,its a breeze
Yes thats what I talked about, and I understood what you explain and makes sense to me. Thank you.
just an update... we got everything together saturday morning, gutted ebpv, ccv, d66 installed.. no leaks!!! great turbo for what he needed. he isnt going any bigger than stage 1's so its a pretty good combo for a drop in imho.
Glad to know everything is working, thanks for the update. .
Its terrible how the PMS attackes us, I was not to ill, sometime ago, but now I want any upgrade BAD
