im trying to put the 89s in, but they seem pretty tight, and i cant get them in as far as they need to be. should i tap them in or lightly grind the jet? are they supposed to be really snug?
definitely make sure they are tight. You don't want anything floating around in your valvetrain. I've never used a jet but have done the same kind of thing before. If you have to grind them don't grind too much
I would still verify pressure with a mechanical gauge. Autometer is probably the best name as far as gauges are concerned. When I installed my new 460 in my 77 F250, I invested in a triple gauge set (temp, oil press and volts) cheap insurance.
As for "floating" around.. impossible... the head bolt keeps the jet in the oil passage and the rocker shaft keeps the jet there as well. The jet has nowhere to go.
I would say your pressures are decent, but not great for a fresh rebuild. Was the entire engine disassembled and cleaned? Possibly an oil galley plug was left out in the process... the one behind the distributor is a pain.
For a total rebuild with an HV pump and stock bearing specs... 80-90 PSI cold, 45 cruise and 25-30 idling.
here are some details of my "rebuild". i removed everything except for the rotating assembly, camshaft and timing chain. the piston walls looked excellent, so i did not think it necessary to remove the rotating assembly and do a full rebuild. i thoroughly cleaned everything, including the rocker shaft assembly. then i reassembled the engine. every seal was replaced, except for the camshaft seal and the valve stem seals. rear main seal was replaced. none of the engine bearings were replaced. i kinda wish i had replaced the bearings while i was in there, but whats done is done. im not pulling that engine back out now...
***add*** when i say i cleaned everything, i mean i scraped and scrubbed for about a week straight. i went through about 10 bottles of gasket remover, carb cleaner and brake parts cleaner. i got it pretty darn clean, however, being that i didnt have an automatic pressure washer, no part was completely perfect, especially not the heads (too many crevices to clean perfectly with just a rag and a scraper). /add
someday i'll build a perfect FE. for now, though, i just want to make sure i have something that will last me a couple or three years in my worktruck. from what everyone has said, mine should be okay for quite a while, which is a relief to me.
thanks everyone for the help. i really appreciate it.
