Sponsored by: Real Truck
Trans expert needed!
Old Mar 6, 2009 | 10:51 AM
bubbasz1's Avatar
bubbasz1
My sons 2001 V10 4X4 4r100 died. Turns out it had a mechanical diode that bit the dust. The trans was rebuilt with E4od replacement parts for the diode, a rebuild kit and a new center support, new pump, and a rebuilt converter.
With installation complete we had reverse, and 1'st, would not shift. We figured that maybe some junk had gotten into the solenoid pack so we replaced that. No reverse but shifted through the gears fine the first time, never got to fast enough to hit 4th. Through a P0782 2-3 shift error, reverse stated working. Cleared the codes no reverse. Checked pressures with a gauge all pressures are good even reverse but it doesn't work. When you put it in reverse it loses engine RPM (just a little) but it will not back up. After screwing around with this pig for a few hours and consulting the book the only thing we could think of was maybe the pump that was installed was a non pwm pump so we ripped it back out and the trans buddy tore it all back down. Everything is just like it was when it went together, no bad gaskets, pump is the same casting all orifices are the same.
Any thoughts? Maybe incorrect shift solenoid although the trans shop only list's the one we have.
Old Mar 6, 2009 | 11:54 AM
99f350sd's Avatar
99f350sd
Did you flush the cooler? Maybe some crap floating around when you started it. Any crap in the bottom of the pan?
Dick
Old Mar 6, 2009 | 12:14 PM
juneau76's Avatar
juneau76
This sounds like a job for Mark Kovalsky. He was a Ford tranny guy for years. I'm sure he'll pick up the thread when he's online again.
Old Mar 6, 2009 | 12:19 PM
bubbasz1's Avatar
bubbasz1
Everything flushed with cooler flush plus added a inline trans filter by the radiator on the return line.
Old Mar 6, 2009 | 07:32 PM
bubbasz1's Avatar
bubbasz1
bump to the top
Old Mar 6, 2009 | 09:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can just guess without looking at the parts, and I guess that there is something wrong with the reverse clutch seals. They may not have been installed right and are leaking. When a code is stored the failure mode is to raise the line pressure, which can make bad seals work, giving you reverse. Clearing the codes will lower the pressure again, so no reverse.
Old Mar 7, 2009 | 12:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hey Mark, I thought only the diesel had the mechanical diode that fails?
Old Mar 7, 2009 | 05:05 PM
Mark Kovalsky
Yes, that's what I was told. All the gas engine trucks were supposed to have the mechanical diode trans replaced before it left the factory. None were sold.
Old Mar 7, 2009 | 05:18 PM
bubbasz1's Avatar
bubbasz1
Well, they lied, maybe Ford should hook me up with a trans, well after 134,000 miles I kinda doubt that will happen.
jsnelson
Apr 15, 2011 09:31 AM
fordmanbrian
Oct 18, 2010 10:41 PM
278broncos
Mar 26, 2010 11:33 AM
bubbasz1
Mar 15, 2009 08:53 AM
