Hey This might sound dumb but I dont exaclty understand what people are talken about when they say change the wire on the fipl sensor, do you change the connector type thing ? or can you buy everything like the whole sensor at a decent price? cause Im haven trans probs the od light stays blinking and it will shift but it runs to about 2500 to 2800 rpms when it does, but if you let off the gas at about the normal spot or speed it will shift normally or at that spot I replaced the speed sensor on the rear end and it didnt fix anything we tested the new sensor and it showed about 1.3 resistanse and I was wondering if that to high ? thanks
have the codes scaned first
the fipl could very well be bad
but i have had quite a few that had a wiring issue and required overlaying the fipl wires to the processor
