? FIPL sensor/ e4od trans question ?
Old Mar 5, 2009 | 08:06 PM
cowboy.2010's Avatar
cowboy.2010
Hey This might sound dumb but I dont exaclty understand what people are talken about when they say change the wire on the fipl sensor, do you change the connector type thing ? or can you buy everything like the whole sensor at a decent price? cause Im haven trans probs the od light stays blinking and it will shift but it runs to about 2500 to 2800 rpms when it does, but if you let off the gas at about the normal spot or speed it will shift normally or at that spot I replaced the speed sensor on the rear end and it didnt fix anything we tested the new sensor and it showed about 1.3 resistanse and I was wondering if that to high ? thanks
Old Mar 5, 2009 | 08:53 PM
archangel's Avatar
archangel
Assuming the injector pump has not been changed out and/or the F.I.P.L. adjustment has not been altered.
I would not bother testing the F.I.P.L. circuit, especially if the original gray colored one is still there!
The F.I.P.L. most often is the cause of any issue with the system.
Of all the ones I dealt with, I never had issue with the wiring, just the F.I.P.L. itself.
I would just swap it out and see if things get better.
Old Mar 7, 2009 | 12:27 AM
ford trans tech's Avatar
ford trans tech
have the codes scaned first
the fipl could very well be bad
but i have had quite a few that had a wiring issue and required overlaying the fipl wires to the processor
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
awolin
Jan 16, 2017 04:26 PM
Tom D
Feb 6, 2016 08:29 AM
Lukkys
Sep 26, 2009 01:23 AM
tomherrick
Electrical Systems/Wiring
Dec 2, 2007 10:04 AM
