05 airbag light
Old Mar 4, 2009 | 03:43 PM
darylcrutch's Avatar
darylcrutch
05 airbag light
my airbag light in my 2005 ford will flash wen i start truck and then stayy on constant....
Old Mar 4, 2009 | 04:51 PM
Still Smoking's Avatar
Still Smoking
If it flashes 4 times then 2 times for a series of like 4 times you will probably either 1 need to clean the wires cause they are corroded or 2 need a new airbag sensor. Mine has done that and I needed a new sensor. The dealer wanted 300 with installation for it but I found one online for 40 bucks from fordpartsguy.com I think it is. I still need to change mine I keep having to put it off. I know it needs to be changed.
Old Mar 4, 2009 | 04:58 PM
darylcrutch
weir is the sensor located or weir would the cleaning need to be done
Old Mar 4, 2009 | 05:56 PM
Still Smoking
I was told its up front by the bumper. I havent got a chance to get at it but from what I was told its in the front bumper. There are a couple threads floating around about this. My internet is real slow so I cant look otherwise I would post it for you. I wrote a thread about a month ago about it. Do a search on Airbag light. I need to find it again and read it over so when I get my truck back I can look for it.
Old Mar 4, 2009 | 08:04 PM
Greg B's Avatar
Greg B
You can probably check out the Ford shop manual from your local library and in the passive restraint section it'll tell you all you need to know. It'll give you the diagnostic procedures, the location, and how to service it.
Greg B
Old Mar 4, 2009 | 08:14 PM
DJPRacer58's Avatar
DJPRacer58
most all airbag systems have yellow plugs and are stamped SRS
Old Mar 4, 2009 | 09:07 PM
darylcrutch
wickid guys i appreciate all the help ill check it out in the AM
Richard24
1997 - 2003 F150
Sep 6, 2012 07:59 PM
fordtrucksforever
1978 - 1996 Big Bronco
30
Mar 14, 2006 07:26 PM
Fullcontact
1983 - 2012 Ranger & B-Series
Mar 8, 2006 06:58 PM
wresleu
Mar 10, 2004 07:27 PM
1997 - 2003 F150
Sep 30, 2002 11:48 PM
