airbag light
Old Mar 8, 2004 | 06:13 PM
wresleu's Avatar
wresleu
airbag light
My airbag light will blink 3 times..pause and then 2 times. Is this a signal of code 32? And if so..how do i find what that means?
Old Mar 8, 2004 | 08:19 PM
Ken00's Avatar
Ken00
Yes it is a code 32, I need to know what year your truck is to look up the code.
Old Mar 9, 2004 | 11:00 AM
wresleu's Avatar
wresleu
it;s actually a 94 Aerostar, but I got no response in the Aero section so thought i'd try here...thanks
Old Mar 9, 2004 | 07:52 PM
Ken00's Avatar
Ken00
OK, no problem. The 32 is Driver Side Air Bag Circuit High Resistance or Open. I suggest you get a detailed manual anytime you work on the air bag system since you can set it off when working on it. Below are the possible causes.
Possible Causes
Excessive resistance across Pins 10 and 11 can be caused by:
A poor connection where the air bag sliding contact connects into the main wiring . The air bag sliding contact connector at the base of the steering column may have excessive resistance between the male and female terminals in the connector.
An open circuit or high resistance in the windings inside the air bag sliding contact .
An open circuit or high resistance in the wiring harness in either Circuit 614 (GY/O) or Circuit 615 (GY/W).
An open circuit or high resistance in the driver side air bag module . DO NOT attempt a direct resistance measurement of the driver side air bag module . Follow the diagnostic procedures to determine if the resistance is higher than normal.
Old Mar 10, 2004 | 06:58 PM
wresleu's Avatar
wresleu
WOW...that sounds like a job for the pro's not the DIYer. Thanks though, that somewhat gives me an idea of where/what to look at. I guess the real concern should be whether the darn thing can go off unexpectedly (which i highly doub is possible).
Old Mar 10, 2004 | 07:27 PM
Ken00's Avatar
Ken00
It won't go off since you AB light is on, the system is disabled. It could go off if you work on it and don't follow the proper precautions.
builtfordtough13
23
Feb 2, 2009 10:26 PM
fordtrucksforever
1978 - 1996 Big Bronco
30
Mar 14, 2006 07:26 PM
jslane47
Jan 25, 2006 11:38 PM
chaser1602
1997 - 2003 F150
Aug 31, 2005 12:37 PM
1997 - 2003 F150
Sep 30, 2002 11:48 PM
