Sponsored by: Auxito
front end shakes like crazy
Old Mar 3, 2009 | 11:35 AM
adamsford's Avatar
adamsford
hi, lately the front end of my '99 f-150 4wd has been shaking really bad when I get up to around 55mph. I replaced the tie-rod ends and got it alligned but it got worse. I recently looked at the lower ball joints by lifting the truck up then lifting the wheel up and there is alot movement and also the idler arm looks to be bad. could these be my problem. please help.
Old Mar 3, 2009 | 11:50 AM
firefighter1416's Avatar
firefighter1416
they certainly arnt helping anything i would say idler arm more than anything
Old Mar 3, 2009 | 12:26 PM
triton_2002's Avatar
triton_2002
ball joints, bad tire(s), bent wheel(s), worn out/bent steering components, check it all out.
Old Mar 3, 2009 | 09:57 PM
steve(ill)'s Avatar
steve(ill)
ball joints and idler arm end normally wear out before the tie rods.
Old Mar 4, 2009 | 07:55 AM
Club Wagon's Avatar
Club Wagon
By all means replace lower ball joints when "there is alot movement". Also note that the front drive shaft is well known for making the front end shake badly. Could be as simple as a dry slip joint that can very easily be lubed, or a bad U-joint.
Old Mar 4, 2009 | 11:41 AM
papajoemrt's Avatar
papajoemrt
Start with the idler arm, then go from there but check everything!!!
Ball joints should be replaced at that age as well.
Old Mar 4, 2009 | 11:50 AM
adamsford's Avatar
adamsford
Thanks for the advice guys, looks like I will be replacing some stuff. I will also look at that slip joint and u-joint. Sure glad i found this site.
Old Mar 4, 2009 | 12:20 PM
Primetime1's Avatar
Primetime1
Thumbs up
Hey, check out the horizontal shock in the front end as well as the parts that connect to it. Sorry I'm bad with the terminology I know that isn't what it's actually called. Dealer calls this the "death wobble". Usually that horizontal shock goes bad and can take out those "arms" that hold it in place by warping out the holes in it. Pretty easy fix all in all
Old Mar 4, 2009 | 02:04 PM
papajoemrt's Avatar
papajoemrt
I do believe the 99f150 doesn't have a steering stabilizer on it. I could be wrong but I know my 02 does not.
Old Mar 4, 2009 | 02:53 PM
Spotty's Avatar
Spotty
Usually the alignment guy will haul you out to the shop and take a big bar and show you how much slop there is in the ball joints, tie rods etc.. It surprises me that they would even align it with bad ball joints. That's the purpose of them running a $49.95 alignment. Most of the time they will find something related to the front end that should be replaced.
When you do the lowers also due the uppers, they are the easy ones. They will come assembled on the control arm. Those are what the alignment guys loosens to adjust camber-caster. Then.... go get an alignment... Good luck with all!
Jeff
Old Mar 4, 2009 | 03:58 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Worn out shock absorbers and out of balance tires can also cause this kind of problem. I had a 1972 F250 camper special that did this same thing. New shocks fixed it. Dan.
Old Mar 4, 2009 | 09:06 PM
papajoemrt's Avatar
papajoemrt
Forgot to add, simply check for packed mud on the back of your wheels.
Old Mar 4, 2009 | 10:47 PM
Club Wagon's Avatar
Club Wagon
Respectfully, does the torsion bar, 2 ball joint, double A-arm "99 f-150 4WD" front end have much in common w/your "1972 F250" coil spring, Dual I-Beam, King Pin front end?
Old Mar 5, 2009 | 04:03 PM
papajoemrt's Avatar
papajoemrt
Hah that last one made me laugh.
pat420swed
Jan 28, 2015 08:12 PM
agmech2
Jan 17, 2011 11:58 PM
AC94EXPLORER
Feb 8, 2008 01:57 PM
Ranch57
May 11, 2006 07:08 PM
jth731
15
Feb 24, 2006 09:44 AM
