New or old motor?
Old Mar 2, 2009 | 03:08 PM
"J"'s Avatar
"J"
New or old motor?
I'm looking for opinions! Everybody has one, so let me hear it. Please.
I currently have a 302ci bored 0.60", in my 79 f100 (orginal engine) I plan on putting a 347 stroker in my truck in the short future. So my question is would you guys put a crete 347 in or build the old 79?
I already have a ford 9" rear end and 4.10 gears!
Old Mar 2, 2009 | 03:24 PM
JBradley500's Avatar
JBradley500
id get a block that's never been bored out and then build a 347 with that. .060" is too much.
Old Mar 2, 2009 | 03:33 PM
"J"'s Avatar
"J"
Thats what I was thinking, but I had someone tell me that the block would work! Here's another question for ya. Did ford # there blocks to the trucks?
Old Mar 2, 2009 | 03:39 PM
JBradley500
no.. after i posted i also thought about telling you to go with a 408w. they are fairly straight forward as a 347 would be and it will make more power and be more reliable.
Old Mar 2, 2009 | 03:43 PM
"J"'s Avatar
"J"
Will that require a 351 block? So I take it that you are not a fan of crete motors! So my orginal motor is not really worth anything, except to say " Its the orginal motor"
Thanks for your input!
Old Mar 2, 2009 | 03:53 PM
JBradley500
yeah... i like custom builds. i dont think it will matter if you have the org. engine in it or not. keep it around if you are worried about it.
Old Mar 2, 2009 | 04:24 PM
79F150/F600's Avatar
79F150/F600
Quick question is your truck a stick? Your awnser will affect what you should do.
Old Mar 2, 2009 | 07:32 PM
"J"'s Avatar
"J"
Auto! With a 9" rear end and currently 4.10's may change to 3.73's.
Old Mar 3, 2009 | 07:59 AM
79F150/F600
Then go with a crate motor if you got the bucks. You see since the old trucks ran the clutch linkage off the engine block and ford stoped doing that with their newer vehicles, a windsor crate motor would not have the casting provision to run the clutch linkage off of. Even though you have a auto figured it was worth while to put that info out there for anyone following this that has a stick and was thinking about the same things as you.
Old Mar 3, 2009 | 12:33 PM
somethingclever's Avatar
somethingclever
how about instead of spending the money on the stroker, just buy a larger OEM engine and put a good set of heads on it.
Old Mar 3, 2009 | 03:41 PM
"J"'s Avatar
"J"
To put a bigger motor in with heads would cost the same as building or buying a stroker. I had a guy price me the bottem end pkg. for $700. An jegs priced me a set of aluminum heads, cam an intake pkg. for $1800.
How much do you think it would cost to put it together?
Old Mar 3, 2009 | 10:11 PM
somethingclever
A stroker bottom end done with machine work is going to be similar in cost to a H/C/I.
You'll make more power with a stock displacement engine with H/C/I over stroker anything with stock heads.
Old Mar 4, 2009 | 08:32 AM
"J"'s Avatar
"J"
I going to build the bottem end, with a H/C/I pkg.
xjpilot
Nov 23, 2011 10:37 PM
Ford347
Electrical Systems/Wiring
Apr 4, 2007 02:12 PM
KFX400
Mar 11, 2007 10:26 AM
79_effie
Aug 5, 2003 09:45 AM
