96 f250
Old Mar 2, 2009 | 02:55 PM
Brad_9876's Avatar
Brad_9876
96 f250
hey guys, heres my problem. I have a 96 f250 with a 5.8 w/o mass air. If its been running and I shut it off and wait about ten minutes and go to start it again, it will turn over way longer than it should and then start. If its cold it will fire right up. I've replaced plugs and wires and coil already. The guy at the local shop says my timing is probably too far advanced. Think he's right? Any help is awesome. Thanks
Old Mar 2, 2009 | 03:06 PM
Lazy K's Avatar
Lazy K
When was the last time you had a tune-up? Stuff like plugs,wires and filters. It could be worth checking the timing and I would also check the fuel pressure. Hope this helps.
Old Mar 2, 2009 | 03:18 PM
Brad_9876's Avatar
Brad_9876
I just did plugs, wires, coil, air filter, and fuel filter this year. Also, when its running, it idles really rough.
Old Mar 2, 2009 | 03:35 PM
Blue Rebel's Avatar
Blue Rebel
Sounds like a fuel issue to me. I would check your fuel pressures
Old Mar 2, 2009 | 03:44 PM
Rulebreaker's Avatar
Rulebreaker
Idle air controller might need replaced. The electrical box on the side of the distributor might be going bad? Just some idea's to check. RB
Old Mar 2, 2009 | 04:02 PM
baldboyford's Avatar
baldboyford
I'd check fuel pressure cold and then when hot. I had a very similar problem with a Mustang only it would crank "all day" and not start after it was already warmed up. Turned out to be a bad fuel pressure regulator. I was just wondering if the IAC could be giving you trouble also. If these aren't the problem I'd check the other things mentioned so far in this thread.
Old Mar 2, 2009 | 04:08 PM
Brad_9876's Avatar
Brad_9876
Whats the easiest way to narrow down my problems? Hook up a fuel pressure gauge and go from there?
Old Mar 2, 2009 | 04:19 PM
guitarnik's Avatar
guitarnik
i would say its timing too fast only cause i had the same problem also check ur batt cables cause it takes more to turn over a warm motor than a cold one
Old Mar 2, 2009 | 04:36 PM
baldboyford
I'd would start with the fuel pressure guage. Check the pressure when the engine is cold and then warm it up and check it and then after you have shut it down for the ten minutes or so and check it while you are attempting to start it again.
cwheeler96
Apr 17, 2014 06:03 PM
Frozen_Joker
Nov 20, 2013 12:02 PM
Evan_P
Aug 8, 2013 06:52 AM
Lead Head
Jan 7, 2013 11:26 AM
NmB
Jul 23, 2011 12:04 PM
