Sponsored by: Real Truck
code p-1633
Old Mar 1, 2009 | 08:03 PM
bayou barataria's Avatar
bayou barataria
code p-1633
Hey guys, 08 250 is throwing a code p-1633 it means low voltage, but everything seems to be o.k.. The other day I ran the batteries down but not too low so I put a charge on them. The computer says the alternator is o.k., but when I clear the code it comes back in about a minute. Anybody have this experience? Or does someone know what to look for? Thanks.
Old Mar 1, 2009 | 11:37 PM
ReAX's Avatar
ReAX
Chassis ground or corroded battery terminals? You have to have a good (low resistance) path for the current otherwise there is a voltage drop. If the chassis ground is clean, check for a voltage differential between where the PCM picks up it's ground and the panel (probably fire wall) the engine grounds to.
Old Mar 2, 2009 | 07:53 PM
bayou barataria
It is a brand new truck, no corrosion, grounds good, I also have two batteries. I am thinking a possible short cicuit somewhere, the dealer replaced the fuel pump last week and the gauge is stuck at the halfway point.
Old Mar 2, 2009 | 08:37 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
With all the power mods you have, I would think dual alts would be something to think about.
Where is La do you live? I live south of Lake charles.
Old Mar 2, 2009 | 09:34 PM
bayou barataria
I wish I had the dual alternators, but I did not order the truck so it does not have them. I keep the batteries charged up by putting them on the charger every couple of weeks, and I don't have any problems. On my last truck I had three batteries and the alternator burned up, so I put an 140 amp and it worked fine. I live in the new orleans area down by lafitte across the bayou.
tangster
All Things Towing
Jan 12, 2017 06:58 AM
Junior81
1983 - 2012 Ranger & B-Series
Apr 17, 2013 08:46 AM
buddy-z
Mar 10, 2012 12:42 PM
nealneu
Mar 30, 2011 11:15 AM
dkellen
Sep 16, 2005 07:51 PM
