Sponsored by: Real Truck
clunk under pass floor?????
Old Mar 2, 2009 | 03:01 PM
shark1979's Avatar
shark1979
when i hit a bump it feel like something is hitting the underside of my pass side floor. i have checked ball joints,shocks tie rod, track bar. what eles could be the problem. friend has 2000 excurison with same problem.
Old Mar 2, 2009 | 03:35 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Sounds like your swaybar links. Look at the bushings to see if they are bad. You can also take the link ends off then tie the swaybar to something and take a ride to see if it still makes the sound. Mine did the same thing and it was the swaybar end links
Old Mar 2, 2009 | 06:29 PM
Fordfanatic4life's Avatar
Fordfanatic4life
swaybar end link bushings would be my guess aswell
Old Mar 2, 2009 | 07:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Yep, I'd say either the end links or the sway bar to axle bushings, or both.
2004 F250 Sway Bar Bushing Replacement
Old Mar 2, 2009 | 10:33 PM
LaredoF350's Avatar
LaredoF350
On mine, it was the swaybar bushings both times rather than the end link ones.
