Wisconsin Chapter Join Chapter Leader:
March Wisconsin chat thread
Old Mar 25, 2009 | 10:05 PM
  #346
fastfarmer's Avatar
fastfarmer
Originally Posted by FORD RANGER
hi all,
yes those ZF TRANNYS are heavy. specially with the transfer case bolted to it.
your better off gettin' your hands on a tranny jack. and a strap...
Hi Jack,
I took the transfer case off. I built a cradle for my floor jack for lowering and raising transmissions, works pretty good. This is my snowplow truck so naturaly everything was rusted and stuck. The studs in the exhaust manifolds had rusted away from 7/16 to about 1/4", twisted right off dispite heat. Coupler where the line fastens onto the slave wouldn't budge, guess I'll get a new master and line too.
Old Mar 25, 2009 | 11:38 PM
  #347
FORD RANGER's Avatar
FORD RANGER
hi pete,
i just push the collar in with a couple of screwdrivers. and it should uncouple from the slave cylinder. kind of a poor design if you ask me.. i've done 2 in my ranger and countless others at the tranny shop i worked at.
Old Mar 26, 2009 | 07:25 AM
  #348
Rogue427's Avatar
Rogue427
OK Who ordered the snow for the weekend? It will be a good weekend to get some inside wook done. I need to runa 220 outlet for the planner and change the compressor over to 220.
Old Mar 26, 2009 | 02:58 PM
  #349
rockin300's Avatar
rockin300
i sure as hell didnt i took my cats off today damn i need some cummins badges now
Old Mar 26, 2009 | 05:07 PM
  #350
drunkdave's Avatar
drunkdave
I bet your truck sounds good nick. Id do the same thing on my bronco, but I just put a new high flow cat on it.
Old Mar 26, 2009 | 06:14 PM
  #351
therifleman556's Avatar
therifleman556
Howdy folks, any vehicle sounds good when you take the muzzle off Nick!
Old Mar 26, 2009 | 06:27 PM
  #352
drunkdave's Avatar
drunkdave
Im back, the lights are back on.
Old Mar 26, 2009 | 06:45 PM
  #353
rockin300's Avatar
rockin300
mine sounds like a cummins/tractor mix
Old Mar 26, 2009 | 07:12 PM
  #354
therifleman556
You should put Farmall decals on!!!
Old Mar 26, 2009 | 07:14 PM
  #355
rockin300's Avatar
rockin300
i should it would get attenion just like if i put cummins badges on it
Old Mar 26, 2009 | 07:16 PM
  #356
drunkdave's Avatar
drunkdave
Farmall would be good, thats not something you see alot of.
Old Mar 26, 2009 | 07:37 PM
  #357
therifleman556
I pretty sure Farmall had a model 300 tractor, It would be pretty sweet if you could get "Farmall 300" on the side!
Old Mar 26, 2009 | 07:38 PM
  #358
rockin300's Avatar
rockin300
i know it would be great i think they were made in the 50s
Old Mar 26, 2009 | 09:02 PM
  #359
fastfarmer's Avatar
fastfarmer
It can't snow, my plow truck is torn apart!
Old Mar 26, 2009 | 09:08 PM
  #360
rockin300's Avatar
rockin300
it will melt its supposed to be 36 with the snow you have a tractor and bucket
