Transmission Fluid Pouring out the bellhousing
Dan,
I remember something about my tranny guy saying that my torque converter on my truck had a drain plug on it. I am shooting from the hip here but could that be part of your problem? I dont know but I would try and check that before dropping the tranny. I have a 99 as well. Just my .02
well I don't know if I caught it time, saw thw white smoke and pilled off the Highway. I already started to pull the tranny so I will drop the inspection plate just to see if the drain plug came out. What more should I expect to encounter, your input is appreciated.
UPDATE: checked drain plug...not the leak
Usually nothing is damaged when the trans dumps the fluid like this, especially if you stop pretty quickly. As the trans empties the pan the clutches let go because there is no pressure. They don't slip, they just release. You also lose lube, but if you stop pretty fast no damage will occur.
Chances are you'll need to replace the seal and maybe the torque converter if the surface the seal rides on is damaged.
jejenkins417
06-17-2011 10:58 AM
skyrader
07-31-2008 03:57 PM
Tyson0317
21
06-19-2008 08:28 AM
