Fan doesnt blow on low setting????
Old Feb 28, 2009 | 03:59 PM
03F2507.3's Avatar
03F2507.3
My fan only blows on the second thru highest setting. The low setting blows nothing. I believe this is a vacuum problem but cant find anything? Any ideas?
Old Feb 28, 2009 | 08:34 PM
gdn's Avatar
gdn
I don't think it is the vacuum prob. - that usually causes the heater to stay on defrost only and will not blow from other vents. The fan losing low speed is probably caused by a bad blower motor resistor. I wish I had access to a service manual to get a good idea of the location, but if what I read through some searches here it should be on the passenger side fire wall near the back of the blower motor, small rectangular block bolted into the air ducts. Like I said I'm kinda guessing here but at the very least I'll bump you back to the top where someone else can add more info.
Old Mar 1, 2009 | 07:23 AM
03F2507.3's Avatar
03F2507.3
bump back up.... someone has to have had this issue?
Old Mar 1, 2009 | 07:47 AM
sflem849's Avatar
sflem849
On my wife's Cavalier and my sister's TrailBlazer the blower motor resister was the problem. They are not Ford's, but I have seen this part fix that problem a ton of times. They are usually $20.
Old Mar 1, 2009 | 08:13 AM
Steve(ON)'s Avatar
Steve(ON)
Mine did the same thing, turned out to be the resistor located on the box around the heater core under the hood on the passengers side of the engine compartment.
Old Mar 1, 2009 | 08:28 AM
Todd0427's Avatar
Todd0427
Mine did that also and it was the resistor under the hood on the passenger side in the box that covers the heater and air-conditioner cores. My wire that went to the resistor were also all corroded and I had to get a new plug from the dealer and splice it in.
Old Mar 1, 2009 | 03:50 PM
JMac444's Avatar
JMac444
Its the resistor, only a 15 dollar part from ford, it controls the speeds on the blower motor, its right next to your blower motor under the hood. The long periods of running melt them or they get corrosion on them. Prob should look into gettin the pigtail for it to the tend to melt to the resistor.
Old Mar 1, 2009 | 04:32 PM
HKusp's Avatar
HKusp
What they all said. My neighbor's '01 5.4 liter F250 had the same isse. Be careful with the plug . His had gotten so hot that it had partially melted. Even so, it's still a relatively cheap fix.
Old Mar 1, 2009 | 05:49 PM
03F2507.3's Avatar
03F2507.3
Ok, I went out and found multiple plugs. Can you be more specific?
Theres a plug going directly into the front of the blower motor, two wires...power and ground. Then theres a plug just a few inches towards the drivers side that has 4 wires. It had some rust inside but when I unplugged it the blower motor still ran so thats not the plug. Which one is it?
Old Mar 1, 2009 | 08:54 PM
03F2507.3's Avatar
03F2507.3
Does anyone have a pic or can better describe which plug and/or wires?
Old Mar 1, 2009 | 10:58 PM
danskool's Avatar
danskool
Go Bills !
This help? Sorry for my .doc version. I can't find a program to convert to .pdf using vista yet. http://www.geocities.com/dirtsplat/C...Components.doc
Old Mar 2, 2009 | 07:45 AM
03F2507.3's Avatar
03F2507.3
The plug that shows as the thermal limiter harness has some rust inside it. So Im wondering if its the harness that needs replacing or if the actual thermal limiter is bad? How can I tell?
Toolman3s
20
Sep 7, 2014 01:09 PM
raye321
Jul 10, 2014 08:16 AM
mike L
Jul 30, 2012 08:07 AM
jdsdidit
13
Dec 21, 2008 04:34 PM
RDC F250 7.3
Jul 16, 2008 12:56 PM
