single shot injectors
Old Feb 27, 2009 | 06:20 PM
crazer42's Avatar
crazer42
is it true that single shot injectors will give me the sound of the older 94-1999 7.3. i like they way they sound a bit rougher
Old Feb 27, 2009 | 06:26 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
it will, but also depending on the tuning, and size of the injectors that you going to install.
Old Feb 27, 2009 | 06:27 PM
PETE'S_6.0PSD
they will be clacking louder for sure, and you also gain some MPG...
Old Feb 27, 2009 | 07:13 PM
Bigcat350's Avatar
Bigcat350
You also gain some HP depending on the size you go with. But when you go to Single Shots you will need your chip programmed.
Old Feb 27, 2009 | 08:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
SCT programmer in your signature won't work anymore if you do go with single shots.
You'll have to use custom tuning to run singles.
Old Feb 27, 2009 | 08:25 PM
Izzy351's Avatar
Izzy351
Jody writes tunes for the SCT, right? Can't he put SS stick programs in it?
Old Feb 27, 2009 | 08:29 PM
Bigcat350's Avatar
Bigcat350
I know he has the SS tunes right for the DP tuner . My big ole truck rocks.
Old Feb 28, 2009 | 12:03 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Put some AA code stock OBS injectors in there, and swap out an OBS PCM too, it'll be slower than ever, but sound cool!
Old Feb 28, 2009 | 12:53 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I don't believe that is the case anymore. I could be wrong but I seem to recall some EPA issues with his tunes on their stuff. Could have been something else entirely too, as some manufacturers never give the real reason they do things when the underlying reason is liabilty.
cowmilker08
May 16, 2013 02:05 AM
brwolfjr
May 14, 2013 10:02 PM
MikeSDK
May 16, 2012 09:44 AM
JTyler11688
Nov 17, 2009 06:14 AM
matt71
Jan 28, 2008 02:34 PM
