97 Explorer engine stall with compresor on
Old Feb 27, 2009 | 01:50 PM
JF94's Avatar
JF94
In 1997 Exploror with a 4.0 SOHC while the engine is idleing and the compressor is on the engine rpm's will drop so low that the engine shuts off. The ac works fine and the engine runs OK above idel speed. This only occurs at idle and only as the compressor cycles on. What is causing this?
Old Feb 27, 2009 | 02:43 PM
marragtop's Avatar
marragtop
Sounds like it could be a bad idle speed control valve. When the compressor engages the idle speed control should open to increase the air to the engine to deal with the increased load put on the engine. I'm sure others will jump in with their thoughts.
Old Feb 27, 2009 | 11:49 PM
lsrx101's Avatar
lsrx101
Here's my thoughts..........I think you nailed the problem.
Old Feb 28, 2009 | 03:44 PM
JF94's Avatar
JF94
Oriley's had to order that part.
In the interium I took the valve off to look at it, I cleaned it (electrical parts cleaner) and dried it with an air compressor. The motor still does the same thing, the ac compressor will cycle on, the rpm's drop to almost shutting off, the compressor clutch disengages and the rmp's go back up to normal idle, then repeat. The up and down cycles are a few seconds long.
Does the problem still sound like the idle air control valve? That valve is $102.00 at Orileys, wow.
Old Mar 3, 2009 | 11:56 AM
JF94's Avatar
JF94
Replacing the idle speed control valve (IAC valve) fixed it! Thank you for the input.
twp
Jun 11, 2008 04:13 PM
wingcommander
Dec 22, 2004 05:12 AM
jhoyle615
22
Apr 14, 2004 10:17 PM
rangman
Electrical Systems/Wiring
Mar 5, 2004 08:35 AM
xbiker777
Mar 25, 2003 12:52 PM
