How to Tell If I have 2 Wheel or 4 Wheel ABS
Old 02-27-2009, 09:01 AM
xjcamaro89's Avatar
xjcamaro89
xjcamaro89 is offline
Anyone know how to tell if you have 2 wheel or 4 wheel ABS, besides trying it somehow, is there a number or code or something that will tell me? Thanks!
Old 02-27-2009, 10:01 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Ford doesn't put the 4 wheel ABS in the trucks. They did for 2-3 yrs back in the early 90's as a test bed, and then went back to Rear Wheel ABS
I'll look in my Repair Manual when I get home though
Old 02-27-2009, 10:06 AM
xjcamaro89's Avatar
xjcamaro89
So there shouldnt be 4 wheel abs in my 2004 STX 4x4 4.6 4 wheel disk brakes. I just need to know cause Napa wants to know if i have 4 wheel or 2 wheel ABS for the new front brake hoses im getting. Thanks!
Old 02-27-2009, 10:16 AM
Catmonkey's Avatar
Catmonkey
Catmonkey is offline
I know I have 4 wheel ABS, and I think it's been standard fare since around 2001 or so.
Old 02-27-2009, 10:27 AM
73f100shortbed's Avatar
73f100shortbed
73f100shortbed is offline
See if you have wires in the front going to sensors by the wheel. Easiest way to check I think
Old 02-27-2009, 10:51 AM
xjcamaro89's Avatar
xjcamaro89
I have a small plastic tube that runs with the brake line into the back side of the hub area. There is also a larger tube looking peice that comes down and connects to the top side of the hub area. Nothing that really looks like wires, they both look like tubes.
Old 02-27-2009, 11:00 AM
Tom's Avatar
Tom
Tom is offline
Both F150s I've bought, both in 2003 and my '07 have stated on the window sticker that 4-wheel ABS was standard...
I've seen lots of dodges with 2-wheel, but never a Ford.
Old 02-27-2009, 11:04 AM
peters_f350's Avatar
peters_f350
peters_f350 is offline
Check each wheel for an electrical connection. Two wheel ABS only has the connection on one axle. Four wheel ABS has the electrical connection on both front and rear axles.
Old 02-27-2009, 11:10 AM
xjcamaro89's Avatar
xjcamaro89
Is there an ABS module inline with the brake lines below the master cylinder. And if i had 4 wheel would both lines go into it, where as if i has 2 wheel, one would by pass the module and the other would go into it. Also where would the electrical connectors be at? Out at the wheel, or on the axle somewhere? Thanks!
Cant beleive that there isnt an easier way to find out.
Old 02-27-2009, 11:17 AM
xjcamaro89's Avatar
xjcamaro89
Can i trust this from Edmonds, it shows standard equipment for the 2004 STX and shows 4 wheel ABS.
2004 Ford F-150 standard equipment at Edmunds
Old 02-27-2009, 11:18 AM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
I believe 4 wheel abs has been standard since 97......the prior generations were not....but i know my 07 is 4wheel
Old 02-27-2009, 11:39 AM
xjcamaro89's Avatar
xjcamaro89
Just ran outside and looked under the hood, the two lines coming out of the master cylinder go right into the ABS module and three lines come out, and im assuming that one is for the back wheels and the other two are for each front wheel. Does this sound right? And i am also assuming that this means i have 4 wheel ABS brakes?
Old 02-27-2009, 11:52 AM
Ford Fx4's Avatar
Ford Fx4
Ford Fx4 is offline
Yes, you have 4-wheel ABS.
I believe it was 98-99 it became standard. I say that because my 97 only had rear wheel ABS.
Old 02-27-2009, 12:56 PM
ggwash21's Avatar
ggwash21
ggwash21 is offline
That plastic tube is a breather for your hubs if im correct.
Old 02-27-2009, 01:16 PM
xjcamaro89's Avatar
xjcamaro89
So the small hard plastic hose is a breather and the large hose that connects to the top of the hub area is for the 4wd?
Quick Reply: How to Tell If I have 2 Wheel or 4 Wheel ABS
