Old Feb 26, 2009 | 05:15 PM
bigenough's Avatar
bigenough
What all engines could i put in my 79 f-150 4x4 with the t-18 tranny, i am engine shoping and found a few good deals but not sure what all would fit, found a 429 for $350.
Old Feb 26, 2009 | 05:25 PM
79 f-150 guy's Avatar
79 f-150 guy
anything will work from a 300-6 to a 514 stroker. small blocks, big blocks, mid-blocks.. they all fit.... a 429 for 350.00 is a screemin deal... i'd go with that.
Old Feb 26, 2009 | 05:27 PM
bigenough's Avatar
bigenough
ok thanks what all would i have to change to make it fit/bolt up the the tranny i have?
Old Feb 26, 2009 | 05:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You should really make your subject line more informational instead of a ton of ???????????????????????????????????????????????
In all honestly you could put any engine you could think of in that truck. Heck, a guy put a Sherman tank engine into a Fox body Mustang.
Just need the correct bellhousing to mate an engine to a transmission.
Old Feb 26, 2009 | 05:30 PM
bigenough's Avatar
bigenough
ok thanks sweet motor, what do you have it in?
Old Feb 26, 2009 | 05:31 PM
75F350's Avatar
75F350
You have a 385 sreies bellhousing already. This will bolt up to the 429 / 460. In fact it is an easy swap. You just have to get some conversion enging mounts and a pass side exhaust manifold from a car, or headers. You wil also have to make sure that you get all of the accessories so you can mount the alternator and power steering, etc.
Lots of aftermarket to support this upgrade.
Old Feb 26, 2009 | 05:34 PM
bigenough's Avatar
bigenough
What would be my best bet 429/460, shall i say what engine is more worthy?
Old Feb 26, 2009 | 05:50 PM
79 f-150 guy
the best bet for low end grunt, like you need in a truck is the 460. they make a boat load of torqe down low where ya need it. the 429 is more of a car big bloock, they make tons of horsepower at a higher rpm...... but if you can get the 429 for that cheap, i'd just buy that and build it into a truck engine. that can be done it's all about having the right induction setup and the rite cam. you need that power down low not up high.
Old Feb 26, 2009 | 06:11 PM
unrulee's Avatar
unrulee
My opinion is that the 429 would be more of a high rpm/hp engine where the longer stroke on the 460 might be more appropriate for truck use.
Old Feb 26, 2009 | 06:16 PM
79 f-150 guy
exactly what i said, the 460 is the best choice........but if you can get the 429, i'd just build a 429 truck engine. you can make a 429 make low end power, you just gotta build it rite....
Old Feb 27, 2009 | 05:46 PM
bigenough's Avatar
bigenough
Thanks! Ill let you all know what i come up with. And get some picks up.
Old Feb 27, 2009 | 05:50 PM
Dr. Dirt's Avatar
Dr. Dirt
I'd get the 429 and get a 460 crank for it.
fordper4mance
Dec 10, 2011 10:23 AM
MartyRayII
Feb 18, 2011 07:17 PM
wiggles789
Jan 21, 2010 04:00 PM
Kmwatkins3321
May 2, 2006 04:49 PM
topo4u2
May 21, 2002 09:18 PM
