Motor Blown...Help!!
Old May 1, 2006 | 04:39 PM
Kmwatkins3321's Avatar
Kmwatkins3321
I've got an 86 f150 4x4. The engine is completely kaput! Can't Rebuild.
I found an awesome 5.0 out of a 90 Lincoln.
I know they have different plenums....
Can anyone tell me what all i have to do to get this motor in my truck and running, and what all is interchangeable??!?
Old May 1, 2006 | 04:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 1, 2006 | 05:14 PM
southernracer89's Avatar
southernracer89
its a fairly easy swap. i did this with my 86 4x4 f-150. my motor came from a mustang tho. just change your intake over to the new block. u can use either heads and the cam out of the lincoln, even though some people say it wont work i had no problems with it, and it should do fine. if you know how to do an engine swap it will be simple. the only difference between the two engines is the intake and cam pretty much. hope this helps.
Old May 1, 2006 | 05:18 PM
Sycostang67's Avatar
Sycostang67
I am sure you will have to swap oil pans too. Shouldn't have any problems though. just put all your truck engine exterior components on the new block and you should be fine.
Old May 1, 2006 | 05:30 PM
southernracer89
i dont know about him, but i was able to use the mustangs oil pan. fitted real nice too. lol. i also forgot about the pullys and all. you will need to put yours on the new engine as sycostang mentioned.
Old May 2, 2006 | 07:00 AM
Kmwatkins3321
Injectors
what about the injectors mine are bad, can i use the lincoln injectors
Old May 2, 2006 | 04:49 PM
Kemicalburns's Avatar
Kemicalburns
forget the lincoln motor. its cam wont work tol well for you application. I say locate an 5.8 and drop it in. its easy and requires little changes. take you same amount of time and money.
1995_f150
Nov 1, 2011 07:34 PM
78oldsmokey
Mar 16, 2006 09:23 PM
steelheader1950
1983 - 2012 Ranger & B-Series
Jan 8, 2006 06:09 PM
Big Block Boy
Oct 27, 2005 06:59 PM
