Thermostat
Old Jun 14, 2010 | 07:44 AM
Blackwaterforge's Avatar
Blackwaterforge
Thermostat
I have ma 66 Ford F-250 that has a 300 engine from a 75. The temp gauge runs right next to the hot line but the truck doesn't boil. I have switched from a 195 to a 180 degree thermostat. I am going to add ac. Should I switch to a 170 thermostat? Should I add a fan shroud? Should I get a gauge and see what the actual water temp is?
Thanks for ya'lls help!
Old Jun 14, 2010 | 08:51 AM
fmc400's Avatar
fmc400
MSEE
You should absolutely use a mechanical gauge to observe the actual temperature. The factory electrical gauge is meant as a warning system more than anything - it's not possible to correlate absolute engine temperature with the position of the needle.
Old Jun 14, 2010 | 11:54 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
X2 Yes, a fan shroud will help with cooling. Lowering the thermostat or removing can actually hurt the ability of the system to cool properly. Deposits built up in the radiator and cooling passages in the block contribute to most overheating problems.
Old Jun 14, 2010 | 07:50 PM
69 f-100 aman's Avatar
69 f-100 aman
Good luck finding a fan shrould for a 300 six,I been looking for 4 years and have not found one,also I have a/c on mine and I'm running a 165 degree thermostat here in Florida and not a problem,but I did go to a flex fan on the engine
Old Jun 15, 2010 | 06:33 AM
chrlsful's Avatar
chrlsful
Russell,
Glad 2 C you're a farrier as well as 'artist smith' - got em both together like the ol' days! Good luck w/the business and camper special.
What yr. is the D60?
Old Jun 15, 2010 | 07:37 AM
Blackwaterforge
Thanks for the replies! Will add a mechanical temp gauge. D-60 is original to truck.
Old Jun 15, 2010 | 09:53 AM
AbandonedBronco's Avatar
AbandonedBronco
Yup, I don't believe I've ever seen a 300 with much of a fan shroud. Mine pretty much had a 1 1/2 foot wide "finger protector" that said CAUTION on it that bolted onto the radiator. Not much of a shroud and I don't believe it did anything.
Old Jun 15, 2010 | 11:54 AM
F-250 restorer's Avatar
F-250 restorer
In the event you do need more cooling ability, you might want to think about an electric fan. You can pick one up from the junkyard for about $30, with its own shroud, and it'll cool much better than the manual fan. I am very pleased with mine.
Old Jun 21, 2010 | 08:49 AM
Blackwaterforge
With mechanical gauge engine runs about 180. When sitting and idling it climbs to 190-200. I am fixing to add a dealer installed a/c unit. Truck has a 180 thermostat. Should I change to a 170 or 160?
Thank You!
Old Jun 21, 2010 | 05:31 PM
69 f-100 aman
Like I said early I run a 160 in mine here in florida and have not had a problem
Old Jun 21, 2010 | 07:19 PM
F-250 restorer
Thank You!
That 'stat should be fine. Those temps should be fine too. But if you get uncomfortable when it is idling, then I'd put in an electrical fan with a thermostat control. You can pull one from the j.yard for about $30, but use caution with the thickness. An adjustable thermo. costs about $60 on Summit. (Get the type with adjustable turn-on, turn-off ****. The non adjustable cost only $30, but don't work at temp they are supposed to.)
The tie-down tie system is crap, IMO. If I were you, I would figure out a way to mount it w/o those cheap ties. You can look up a thread of mine: radiator swap.
Old Jun 29, 2010 | 10:34 AM
Jag Red 54's Avatar
Jag Red 54
Running a lower temp thermostat will not help in preventing overheating. All it will do is lower the temp when you are running down the road with lots of air flow and the radiator is not at max use. This will only accomplish one thing and that will be to lower your engine efficiency. (Lower mpg) This is not a good idea. Running your engine between 180 and 190 is good. !50-160-not good. Good luck, Jag
Old Jul 12, 2010 | 06:55 AM
Superred2's Avatar
Superred2
F-250 restorer, what's the double fan out of? I am thinking about upgrading the cooling in my 86...
Old Jul 12, 2010 | 12:31 PM
F-250 restorer
It is out of a late model Ford WindStar mini van. It is too long for most rads--30". Although it looks good, I ran into clearance probs with one fan on the w.pump. I ended up cutting the shroud along the center (see the above photo), and using one of the fans as a puller, which is a high volume fan and works year round. Then on the outside I mounted a 'pusher fan' from a 94 Tercel. I didn't want to be bothered with an in cab switch for the second fan, and having to always watch the temp during the hotest summer months, or when towing, so I hooked up a plug-in connection for it. When towing, or during August/September, I just connect it and it comes on/off automatically like the puller fan. I really like the system.
**Notes: The fans on the F. Taurus are known to be high volume. The late model Saab 93's have a nice dual set-up. With the 4.9 it is all about thickness. However, the nice thing about duals is they allow a bit of movement/placement of a pulley between the fans.
A concern with the electrics is how many amps they are drawing, and whether your alternator can keep up.
Good luck.
Old Jul 14, 2010 | 07:40 AM
TorqueKing's Avatar
TorqueKing
My quick & dirty $0.02:
Carbureted engines run best with a 180 T-stat. Anything less and you'll find sludge if you remove a valve cover. Synthetic won't leave sludge even at 160, but the carb will idle better at 180- and I wholeheartedly support the notion that going less than 180 will not improve cooling efficiency- I think that is wise advice! If you go to a 195 you'll probably get problems with pinging. For tuning and drivability, the 180 seems to be the optimal trade-off.
Fuel injected motors like the 195's- and though I'm a Georgia boy all my life, I'm also a man of service and I've been to every corner of this great country, and when I've been blessed to visit the great northern and western states at great elevation I've sure loved having the heater from my 195!
F-250's got some great value advice for putting together a solid and cheap system. I've always done it the expensive way because I'm not as wise but I'm learning! A good hybrid solution might be to use an aftermarket relay with adjustable fan 'stat from Jegs or Summit (usually $30-40) and boneyard fans, but there may be a way to do a relay with stock-replacement parts too. I defer to the experts for that...
