need quick help and search isnt getting results i need. My Parents have a 2000 F250 with the Triton 5.4 that the truck is totaled. My Father in-law has an '03 F150 that also has a 5.4 but the interchange book says they are not the same. Can they be interchanged?
They should be the same. The 2003 may have the updated cylinder heads with 8 threads per hole instead of the troublesome 4 threads per hole of the earlier engines. Other than that they should be identical. Good luck!
Why would there be a difference? The F-250 is a LD model so it is the same body. The transmissions are different. The F-250LD will have the 4R100 and the other one will have the 4R70W.
The only possible thing that I can see there is a difference in the flex plates. That is rectified by swapping in the one that is appropriate for the transmission used.
Okay, i'm taking your word for it. Another guy said they only made two different 5.4's and as long as it was the L engine code it would work. The interchange book has been wrong before, but not often.
i recently was searching for an engine...and apparently the 97-98 engines are different from the 99 and 2000 - 03 are the same but i put a 2000 in my 99 and interchange said its 99 only.....just my input .....
