Sponsored by: Auxito
Quick engine Question
Old Feb 26, 2009 | 01:10 PM
Dforgy's Avatar
Dforgy
need quick help and search isnt getting results i need. My Parents have a 2000 F250 with the Triton 5.4 that the truck is totaled. My Father in-law has an '03 F150 that also has a 5.4 but the interchange book says they are not the same. Can they be interchanged?
Old Feb 26, 2009 | 01:46 PM
KingRanchMan02's Avatar
KingRanchMan02
They should be the same. The 2003 may have the updated cylinder heads with 8 threads per hole instead of the troublesome 4 threads per hole of the earlier engines. Other than that they should be identical. Good luck!
Old Feb 26, 2009 | 01:57 PM
Dforgy's Avatar
Dforgy
Even 1/2 ton vs 3/4 ton?
Old Feb 26, 2009 | 02:08 PM
KingRanchMan02
Why would there be a difference? The F-250 is a LD model so it is the same body. The transmissions are different. The F-250LD will have the 4R100 and the other one will have the 4R70W.
Old Feb 26, 2009 | 03:59 PM
Dforgy's Avatar
Dforgy
But that's one concern. Will engine code L blot up to both transmissions?
Old Feb 26, 2009 | 04:07 PM
KingRanchMan02
The only possible thing that I can see there is a difference in the flex plates. That is rectified by swapping in the one that is appropriate for the transmission used.
Old Feb 26, 2009 | 04:38 PM
Dforgy's Avatar
Dforgy
Okay, i'm taking your word for it. Another guy said they only made two different 5.4's and as long as it was the L engine code it would work. The interchange book has been wrong before, but not often.
Old Feb 26, 2009 | 04:53 PM
KingRanchMan02
There are two different 4.6L engines, a Romeo and a Windsor. The 5.4L are all Romeo engines.
Old Feb 26, 2009 | 05:36 PM
Dforgy's Avatar
Dforgy
ahh ha, thank you. I dont know why the interchange book says no, but I appreciate the help King.
Old Feb 26, 2009 | 06:25 PM
LxMan1's Avatar
LxMan1
The 5.4L are Windsor, not Romeo!!!!!!!!!
The difference is that the SD didn't get the PI engines until 01 I believe. Our 2000 F250SD where I used to work did not have a PI 5.4L.
Old Feb 27, 2009 | 10:58 AM
KingRanchMan02
Thanks for the correction LXMan1!
Old Mar 2, 2009 | 09:37 PM
rickapalooza's Avatar
rickapalooza
i recently was searching for an engine...and apparently the 97-98 engines are different from the 99 and 2000 - 03 are the same but i put a 2000 in my 99 and interchange said its 99 only.....just my input .....
Old Mar 2, 2009 | 11:45 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
lol i have a 2002 in my 99 FTW.
FSBARAK
Sep 4, 2012 11:03 PM
Southern Cowgirl
Modular V8 (4.6L, 5.4L)
Sep 1, 2011 04:56 AM
Trials1Rick
Jan 3, 2004 08:00 PM
