Sponsored by: Real Truck
engine lite
Old Feb 26, 2009 | 09:58 AM
PEDRO.SD's Avatar
PEDRO.SD
engine lite
f-250 ,02 v10 85,000 miles.The engine light comes on while towing. The light will go off after towing. Seem to be using oil. Had the fuel pump replaced once. Plugs replaces and injectors cleaned. Truck seems to run fine. Whats going on. Would a coder be a good thing to have?
Old Feb 27, 2009 | 10:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You really have to read the codes to find out what the computer is complaining about.
Not sure about what code reader to use on the V10, but you could get a place like Autozone to try reading them for free.
Old Feb 27, 2009 | 10:49 AM
ReAX's Avatar
ReAX
Any gas OBD2 reader with a ford module should work fine. The ford module isn't strictly needed, but it's nice to view OEM specific faults.
The problem could be many things, reading the codes would be the easiest way to find out.
Old Feb 27, 2009 | 11:48 AM
senix's Avatar
senix
I'd be looking at the O2 sensors. Autozone can read that code if it is.
Franksporttrac
Jun 5, 2012 12:02 PM
ramrod2624
Aug 31, 2011 09:58 AM
goldsmje
41
Nov 15, 2009 07:12 PM
stavros
Mar 22, 2007 12:18 PM
