4.6 premaure spark issues
Old Jun 4, 2012 | 09:56 PM
Franksporttrac's Avatar
Franksporttrac
Question 4.6 premaure spark issues
have a 2007 sport trac with v-8. 92k check engine light comes up with premature spark, firing issues. Note light will go off for a couple of days after towing boat (4000 lbs with trailer) Dealer changed plugs at about 77k, coil has been replaced on noted cylinder. lifter that one side seems a little noisy.
Engine light started coming on intermittantly after spark plug change, but has been pretty much on with the exception of after towing, but comes back on after about 100 miles. I have been running synthetic since about 12k, can't quite figure this out. HELP emmision testing due soon
Old Jun 5, 2012 | 01:19 AM
aquanaut20's Avatar
aquanaut20
The synthetic is OK.
What fuel are you using, Octane?
Sounds like you may have some pre-ignition! Carbon build up in cylinder or bad plugs (heat range)... Philip
Old Jun 5, 2012 | 06:16 AM
critterf1's Avatar
critterf1
What type/brand of plug was installed?
Old Jun 5, 2012 | 06:38 AM
shorod's Avatar
shorod
Is the code you are getting for a misfire (PO030x where 'x' is the cylinder number) or something different? I've not heard of a "premature spark" diagnostic code.
-Rod
Old Jun 5, 2012 | 10:11 AM
Franksporttrac
codes
it is a misfire code, seems to run ok, but possibility of some mechanical noise (place screwdrive in that area you can feel something is off, like I said coil hads been replaced
Old Jun 5, 2012 | 10:47 AM
aquanaut20's Avatar
aquanaut20
The miss fire will account for that noise, Do some testing/diagnostics, dont continue to guess..
Back to the question of the plugs, what do you have in there??? ... Philip
Old Jun 5, 2012 | 12:02 PM
Franksporttrac
My local tire place has recommended I take it to ford, I will check the basics, cinnections etc thanks
Bryandoyle
Jan 22, 2017 01:17 PM
Brittany Madl
Jan 14, 2017 11:32 PM
HelenB
May 17, 2016 04:38 PM
tjw11235
General Automotive Discussion
Jun 27, 2011 01:22 PM
motif
1997 - 2003 F150
Mar 10, 2003 06:16 PM
