95 350 abs light flashing
Old Mar 22, 2007 | 11:25 AM
stavros's Avatar
stavros
Hello
95 F350 460 AOD
The abs light started flashing and the truck when turn off will not go into drive in as much as the shifter is locked. Its easily overcome by placing it in nuetral and starting it to get going and once going seems to be fine.
Trans has been replaced but the truck works hard, it tows a 10000lb hydroseeding unit.
Any thoughts would be appreciated
Old Mar 22, 2007 | 11:37 AM
JoeVB's Avatar
JoeVB
The ABS system/light is pretty simple. The only thing you really have are the ABS computer, the valve itself and then power and grounds.
If your light is on then you have power. If you haven't screwed with any other wires then your grounds are OK.
You can read this thread to see what I did to get the codes out of my ABS computer...https://www.ford-trucks.com/forums/s...ad.php?t=445265
Old Mar 22, 2007 | 12:18 PM
stavros's Avatar
stavros
Thanks Joe
I looked at the fuse box and 13 is blown. I probably should have checked before wasting your time so thanks.
Lighttrucker
Dec 17, 2015 01:08 AM
Lighttrucker
Nov 16, 2015 06:35 AM
pnp522
Dec 3, 2013 10:55 AM
tmartin2
Jul 19, 2011 11:05 AM
lpaz1
Nov 25, 2006 08:38 AM
