Sponsored by: Real Truck
ATF Question
Old Feb 26, 2009 | 08:44 AM
C1USTERDUCK's Avatar
C1USTERDUCK
Question ATF Question
Thinking about running AmsOil Synthetic ATF. wondering if anyone has any thoughts. also had a question about service intervals. My 07 F350 6.0L has just over 36000 miles and was wondering how much service i need to do, whether just a bypass trans filter change, in pan filter change or even a full blown flush. thanks for any imput.
Corey.
Old Feb 26, 2009 | 09:02 AM
motown's Avatar
motown
If your trans spec's for the SP fluid, I would stick with the Motorcraft fluid.
Old Feb 26, 2009 | 09:18 AM
C1USTERDUCK
Even though the Amsoil is a "Universial" and says its applicable to the Mercron SP fluid type?
Corey.
Old Feb 26, 2009 | 09:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I wouldn't use AMSOIL in a TorqShift. That trans is EXTREMELY sensitive to having the right fluid. If it doesn't work you are looking at a very expensive repair that is not covered by Ford's warranty. Maybe you'd be able to get AMSOIL to warranty it.
MERCON SP is already a synthetic. What are you gaining by using the wrong fluid?
Old Feb 26, 2009 | 10:36 AM
cartmanea's Avatar
cartmanea
My dad was talked into Amsoil ATF by a friend who is a dealer. He's had no problems and its been about 15k miles, shifts great and he tows heavy (grossed 31.5k before). Another friend who owns a tranny shop prefers using the Amsoil in TorqShift service, hasn't had any problems. Personally, I'll stick with SP for now.
Old Feb 26, 2009 | 10:41 AM
C1USTERDUCK
thanks for the imput. I was on the fence about using amsoil and have decided to use motocraft. for half the price, cant go wrong either...
Corey.
Old Feb 27, 2009 | 08:32 AM
aaronbrace's Avatar
aaronbrace
Amsoil
I use amsoil everything I own. Crankcase oil, gear oil and transmission fluid...With one exception...My Torqshift. That gets Motorcraft Mercon V. I am sure the Amsoil would be fine but I don't want to chance it. The Motorcraft is already synthetic and I get it for a reasonable price at the local dealer.
---Aaron
Old Feb 27, 2009 | 09:55 AM
cartmanea's Avatar
cartmanea
I hope you mean Mercon SP, otherwise what is the point of using Amsoil everywhere except in the transmission where you use the wrong fluid instead.
---Aaron
Old Feb 27, 2009 | 08:44 PM
aaronbrace's Avatar
aaronbrace
Yes, of course, Mercon SP
Old Feb 28, 2009 | 04:46 AM
juneau76's Avatar
juneau76
Ford can't deny your warranty because you're not using their lubricant; it's a federal law under the Magnuson-Moss Warranty Act. The law states that if that there is the only fluid that can be used to maintain your warranty then they must provide it to you free of charge. I believe Amsoil's warranty reads that they will warranty the repair if you can prove that using their oil caused the damage. Personally, I run Mercon in mine.
Old Feb 28, 2009 | 09:16 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Bet that'll be easy to do!
Another vote for sticking with Motorcraft.
Old Feb 28, 2009 | 10:12 AM
C1USTERDUCK
I just want to say that I have just finished flushing my trans with mercron sp. Thanks again for all the imput, it made my descision really easy!
Corey.
Old Feb 28, 2009 | 10:49 AM
Mark Kovalsky
That's not true. Ford can and does mandate a specification for the fluid that maintains the warranty. AMSOIL does not submit their fluid for analysis, so they cannot state that their fluid meets MERCON SP. If you read their label carefully you'll see that they do not state that it meets MERCON SP specs.
If you use this and have a failure Ford is not on the hook for the repair. You used the wrong fluid, you pay for it.
Yes, they do. That's why I said maybe you could get AMSOIL for pay for any damage. Maybe they will.....
Old Feb 28, 2009 | 01:57 PM
Gage2502's Avatar
Gage2502
Question does the TorqShift tranny have two filters? One in the tranny pan and the other inline? I think I to will stick with the Motorcraft ATF.
Thanks ~Gage~
Old Feb 28, 2009 | 02:06 PM
RDC F250 7.3's Avatar
RDC F250 7.3
What can make the trans not want to shift into OD, Also my Tow/Haul light is blinking. Fluid is full, less than 13k miles on the fuild, I have not changed the pan filter. I got the truck 13k miles ago, changed fuilds, install an ebay 6.0 engine. Has never gave me any problems. Thanks for the upcoming help!!
Bobby
