Door Rattling???
Old Feb 27, 2009 | 05:21 PM
96powerstroke's Avatar
96powerstroke
what exactly is the weatherstripping mod, my driver side has a rattle and it getting really annoying.
Old Feb 27, 2009 | 05:27 PM
jwhitetail's Avatar
jwhitetail
When my truck was new driver's door was loose when on a dirt road,so i took it to dealer this guy showed me how to tighten the door. Take a Torx bit loosen the two torx bolts on the door latch the one on the door frame, tap them in with a hammer. You can tell how much you moved it if you look at the door when it's shut if it's flush with the body or sticking out some, when you tap the latch in tighen it down shut the door and you will see the diff. Test drive it down a dirt road with window down and your arm resting on it, if it's still loose stop and tap it a little more.
sagmill
Oct 23, 2017 09:41 AM
DGMFORD
Feb 14, 2011 11:14 PM
90xlt4x4
Dec 15, 2005 10:57 PM
Attaboy2k2
Apr 11, 2005 01:45 AM
damone
Jan 22, 2005 10:21 AM
