Sponsored by: Real Truck
Front crash bar
Old Feb 25, 2009 | 08:37 PM
high ho silver's Avatar
high ho silver
Front crash bar
When did Ford start putting them on the SD? What years have them and what configuration?
Old Feb 25, 2009 | 08:39 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Are you talking about the second, low bumper to keep us from running over little cars? If so, my 2004 has it.
Old Feb 25, 2009 | 08:47 PM
aldridgec's Avatar
aldridgec
1999, the blocker beam was an original design on the trucks. Some it can be unbolted, others it's a welded part of the front spring shackles.
Old Feb 25, 2009 | 08:49 PM
high ho silver
Mine doesn't have one so I don't really know what it looks like. Was trying to figure out where and how it mounts.
Old Feb 25, 2009 | 08:55 PM
ReAX's Avatar
ReAX
We call it the miata bar, but it's a shapely say 1.5x2.5" bar that connects the two front shackle mounts. If you look in the wheel well, there is a rather ugly and dust collecting bracket, that's it.
Old Feb 25, 2009 | 08:59 PM
high ho silver
Hummmm...Previous owner must have removed mine. Don't have anything between the shackle mounts except....the bottom of the radiator
Old Feb 25, 2009 | 09:08 PM
ReAX's Avatar
ReAX
There was a break in old hanger kits. I want to say it was early 99 vs late 99. The late had the bar attached to the kit. My 2002 has bolts holding down, so perhaps the after 99 were removable.
Old Feb 25, 2009 | 09:12 PM
high ho silver
Thanks! I'll have to check with the stealership for availability.
Old Feb 25, 2009 | 09:22 PM
aldridgec's Avatar
aldridgec
Then they must have went back to welded in for 05 up. I'm pretty sure I remember the newer trucks not being removable, but my 04 and 02 were.
Old Feb 26, 2009 | 04:58 PM
high ho silver
I checked underneath and all I see are two heavy duty tabs (for better words) each with two holes drilled in them welded to the frame about 6-8 inches aft of the leaf spring perches. Is that where they mount?
Old Feb 26, 2009 | 05:15 PM
aldridgec's Avatar
aldridgec
No, those are for the sway bar mounts on the 2wd trucks. The same base frame is used for both drivetrains. The mounts are on tabs farther up on the front spring hangers
Old Feb 26, 2009 | 07:29 PM
brwolfjr's Avatar
brwolfjr
contact your local snow plow dealer. That is the first part to go.
Old Feb 26, 2009 | 07:52 PM
medtech's Avatar
medtech
yup, just installed a plow on my 06 and had to remove the blocker bar to make room for the plow mount.
Old Feb 26, 2009 | 08:37 PM
Zip's Avatar
Zip
That's what that thing was. I took mine off when I installed my leveling kit.
Old Feb 26, 2009 | 08:40 PM
high ho silver
What's a snow plow dealer in Ga?.......Out of business. We aint seen none since 73'.
hmcfly
Feb 20, 2017 11:07 PM
gogoat
Oct 9, 2016 05:15 PM
Cajun66
17
Nov 17, 2010 04:35 PM
87carbed
Jul 26, 2006 05:06 AM
big302
Aug 24, 2004 08:18 PM
