I just got my new 460 running in my 77F250. Not sure of where the base timing should be as the sticker under the hood is gone. I set it at 6 deg BTC for now and she seems to run good there. The engine has:
I have seen in the books for stock anywhere from 6 to 14. I usually run mine around 10.
If it starts good and shuts off fast with no pinging when accelerating then its close.
I don't have any books on your truck to tell you for sure. Some one else here might.
I believe my compression is 9.5:1. I don't know cam specs, just seen it called "RV cam", I'll try and search for specs. The motor runs real good, no pinging, accelerates without any hesitation. I pulled spark plugs this past weekend and they look perfect after about 400 miles. I can't find anything on timing specs. The motor rebuilder recommended 30 deg of total timing at 2800 rpm but said nothing about base timing.
