Ford 460 oil filter adapter part numbers
You don't mention what year, and I assume this is the right angle adapter that points the filter at the lower rad hose.
I found that in another thread I replied to ( https://www.ford-trucks.com/forums/2...problem-2.html )
the old part is obsolete from the dealer.
Fel-Pro 447RR is listed as replacement for the seal but any proper sized O-ring should work. I just used a universal oilpan drain washer under the banjo bolt head on mine.
I hope this helps..
I hope this helps..
Yeah it is the right angle adapter, from an 80-86 truck. The face that came from touching the block looked like it had a foam gasket about the diameter of a regular filter if it was to contact that area. And it looks like it was loose when someone re-installed it so it was offset and oval now, and squished thinner then paper.
Thanks that link was perfect. That last picture showed exactly what I needed.
Northern Econoline
08-01-2013 10:40 PM
keiths78f150
16
07-28-2013 10:43 PM
patmedic
13
01-17-2011 08:18 AM
