E4OD Compatibility
Old Mar 19, 2009 | 11:28 PM
  #31
aurgathor's Avatar
aurgathor
If you are *really* tight on money, the C6 can save you some $$ in the short run. But you'll need a longer drive shaft and some linkage modifications for the 4WD, which will cost you some extra.
Old Mar 20, 2009 | 08:51 PM
  #32
TripXAnarchy99's Avatar
TripXAnarchy99
well its not a huge rush i'd like to just find the E4OD to go in again, and its not really the money either. I'd like to try and save a few bucks getting a used one that i know works, but i may end up getting a rebuilt one.
Old Mar 21, 2009 | 02:26 AM
  #33
aurgathor's Avatar
aurgathor
Look at eBay. Rebuilt ones from around $900 and up. Some even comes with 5 year unlimited mileage warranty. Of course a warranty backed by a small shop may not worth as much as one backed by a car maker, but still.
Old Mar 21, 2009 | 04:26 AM
  #34
danlee's Avatar
danlee
If you have to pay 2 way shipping from a shop in Timbucktoo, that warranty may not be worth much. If the shop is within driving distance, then it could be OK.
Old Mar 10, 2024 | 10:09 PM
  #35
Gonzo97F250hd7.5L4x4's Avatar
Trailering
I realize this is an old thread, and not to question/challenge your knowledge and experience, I'm quite confident your opinions are much more valuable, and a better solution or at least a more well thought out solution, than mine on this matter. I did find another option, which is fabricating new drive shaft when switching between 2wd e4od and 4wd e4od, to not only add length to shaft to make up for missing transfer case, but also to avoid changing output shaft in 2wd trans that's being installed where 4wd e4od had been...
TheProfessorofTOOL
Engine Swaps
May 7, 2015 08:45 AM
firegod75
Oct 10, 2014 09:28 AM
clong
1997 - 2003 F150
May 8, 2014 10:36 AM
MUSKRATT2
Mar 9, 2012 07:11 PM
