Yes, installing the right parts will make it a 460 trans. I don't know which ones are different, I just know that there are several differences and the small block parts are not as strong.
I'm going to look at an '83 F100? 2WD with a 302 and a bad tranny. I asssume that an '83 will be a carb motor.
What tranny should I expect? AOD, AODE, or C4?
Will my small block E4OD tranny mate to a carb small block?
I plan to try to build a controller for the E4OD, and use this truck as a test bed.
It could be an AOD or a C6. The AODE started in 1992.
The small block E4OD will bolt to the engine.
Good, that's what I thought. If this works out, I should be able to sell this truck and get enough to buy a rebuilt E4OD to mate to my 408. I'll just have to duplicate my controller.
I looked at that '83 F100 today. It's not pretty, but it's cheap. The 302 purrs like a kitten. It has an AOD. The owner says the OD slips when you engage it. It runs in Drive OK.
I bought the '83 F100 with the 302 and bad AOD. I'll pick up my small block E4OD on Thursday.
I have a question about the drive shaft. Since the E4OD tranny is so much longer, I will need a shorter drive shaft.
Can I use a drive shaft from a later model RWD F100/F150 that has an E4OD tranny? What year/Model?
Is there any issues with torque converter from the E4OD and the 302 carb motor?
Can I operate the E4OD in any gear, if there is no controller connected?
I got my E4OD manual today. Unfortunatly it's a service manual, and I need Engineering Design information. However there is some useful information in it.
The service cable defines:
Solenoid 1 as White to Black leads.
Solenoid 2 as Red to Black leads.
Transmission Oil Temperature is the Yellow leads.
Solenoid 3 Converter Clutch is Green to Black leads.
Solenoid 4 Coast Clutch is Blue to Black leads.
The Orange leads are the Electronic Pressure Control.
What is the Line Pressure Tap? Is there a pressure sensor?
With no controller it will operate in 1st gear when the shifter is in 1, second when the shifter is in 2, fourth when the shifter is in D, and reverese in R.
The line pressure tap is a 1/8" NPT dryseal threaded boss on the driver's side of the transmission. It is connected to line pressure. There is a plug in that tap from the factory. A service tech would remove the plug and install a gauge to diagnose transmission problems. There is no pressure sensor anywhere on the trans.
By fourth gear you mean it will go into OD when placed in drive?
That's good that it will operate without a controller. I will be able to move it around after I swap trannys.
Can you suggest a suitable donor for the driveshaft?
Not to post too far off topic, but its better than starting a new thread for a simple question. My E4OD trans went bad in my 5.8L 4x4, I was told by a friend that the C6 will bolt directly up and is a much better trans than the E4OD? Anyone try this or know anything about it. Thanks alot... My search for the E4OD trans has extended over 6 months now and I'm getting desperate and looking for alternatives. Thanks again
A C6 is a 3 speed transmission, while an E4OD is a 4 speed. The extra gear is an overdrive gear and helps gas mileage while cruising. The E4OD was developed to replace the C6 and inherited it's reliability.
