1986 F250 Brake light problems
Old Feb 23, 2009 | 08:09 PM
ladderdawg's Avatar
ladderdawg
I own a 1986 F250, this is the problem that I am having:
The brake lights come on when I turn on the headlights. The brake lights do not work at all when I push on the pedal. I replaced both bulbs, but have the same problem. Could it be the brake pedal switch?
Any advise would be helpful.
Ladderdawg
Old Feb 23, 2009 | 09:08 PM
IrishBusDriver's Avatar
IrishBusDriver
sounds like some wires are crossed or shorted. The tail lights should come on with the headlights, not the brake lights. Check the wires at the tail/brake light and under the rear of the truck where they tie in , up above and behind the bumper. Once you have the tail lights working then you can work on the turn signals and brake lights.
Old Feb 24, 2009 | 09:43 AM
bashby's Avatar
bashby
could be a bad ground for the tail lights backfeeding the brake lights
Old Feb 24, 2009 | 11:54 AM
86bigred's Avatar
86bigred
i agree with bashby,bad grounds can cause massive headaches. i always check my grounds first,most of the time that cures the problem.
rusbukt
All Things Towing
Jan 31, 2016 06:35 PM
mario9272
Jul 8, 2013 11:03 AM
SonofaFord
Sep 30, 2011 06:51 PM
wagontrader
Feb 14, 2011 02:24 PM
fromm
1978 - 1996 Big Bronco
30
Jul 3, 2009 07:31 PM
