Electric brake issue
Old Jan 31, 2016 | 06:19 PM
rusbukt's Avatar
rusbukt
I have a 2005 F250
When I apply power to the electric brake controller manually the trailer brakes work as should.
When I depress brake pedal the trailer brakes do not work at all.
All the lights on truck and trailer work as should.
All the brake lights come on when brake pedal is depressed.
It's acting as if there is no power from brake pedal to electric brake controller.
Any ideas? Thanks in advance !
Old Jan 31, 2016 | 06:30 PM
RV_Tech's Avatar
RV_Tech
Are you testing the pedal with the truck moving or static? You will have nothing off the pedal until you are moving more than 5 mph. You can not test a controller using an accelerometer until you are moving and it works proportionally with the truck brakes so you will not feel it work.
Steve
Steve
Old Jan 31, 2016 | 06:35 PM
rusbukt's Avatar
rusbukt
Steve
Steve
Static
Had trailer up off the ground.
Thanks Steve.
Lance Nelson
2015 - 2020 F150
Jun 26, 2019 09:47 PM
Wildcat313RE
6.7L Power Stroke Diesel
Apr 2, 2017 04:20 PM
Headviking
6.4L Power Stroke Diesel
Oct 17, 2014 10:35 AM
firewood truck
Jul 8, 2012 12:28 PM
Mid_Mo_F100
1997 - 2003 F150
Apr 15, 2007 09:34 PM
