odd clicking sound in engine?
As a general rule of thumb (so I've been told) is that an engine in good condition should use roughly 1/2 to 1 quart of oil per thousand miles.
I've also been told that if you have an engine that doesn't use any oil over a couple of thousand miles (dipstick level doesn't change much), that you may have a problem.
As it was explained to me, the oil is there to not only lubricate, but to clean and trap contaminants from the internal workings of the engine.
So, if you have an engine that does not seem to use oil (going by the dipstick), it means that something undesirable is causing the inside of your engine to be very dirty. The oil vapor would still be burning off through the PCV system, but the lubrication quality would be rapidly diminishing because of all the dirt that replaced the vaporized oil.
Last edited by Beastly; Feb 22, 2009 at 10:23 PM. Reason: Fixed grammar, and poor wording choices.
Did the ticking noise go away after topping off the oil?
From my own personal experience with some of my engines being about a quart low after about a thousand miles, and seeing how dirty oil gets after a few thousand miles, it sure seems like there is some truth to it. I have also heard of engines "making oil" before (not often, though), which isn't possible, so this would seem to lend some support to the theory, as well. (I've seen gas in the oil before, but that's not what I mean here.)
How much oil vaporizes, and gets circulated through the positive crankcase ventilation system, and out the exhaust pipe, is a question I don't have the answer to. I would expect it would vary by operating temperatures, typical driving distances, etc., since the oil has to get warm enough to vaporize in the first place.
The only way I know of to get conclusive evidence would be take oil samples when you put new oil in, and oil samples when you change the oil, recording the actual number of quarts, and ounces, at the beginning, miles driven, the actual quarts, ounces, drained, and sending samples of each off to a laboratory like Oil-Scan, to have them do an analysis to see how much dirt is actually in the oil, and how much oil vanished. It seems like more work than I'm inclined to do to find out the answer.
The auto makers want people to have a good experience with their vehicle, and want them, their family, and their friends, to buy their next car from them, too.
Between the normal wear, and tear clauses, and the consumer maintainence requirements that are spelled out in the owners manual, I would think that the auto makers are already well covered to avoid financial responsibility of repairs, if they choose to play it that way.
However, these companies usually care more about their corporate image than the minor (to them) cost of replacing the occasional engine for someone who got a lemon, and depending on the circumstances, will sometimes bend over backwards to make it right with the customer. It's a lot harder to overcome negative word-of-mouth, than it is to make up the cost of an engine swap.
P.S. to the original poster: Sorry for hijacking the thread.
My apologies also for the hijacking, post here next weekend and let us know how it went for you!
