Adding remote entry
Old Feb 21, 2009 | 11:59 PM
geta4x4's Avatar
geta4x4
Adding remote entry
What do I need to add a remote entry module on a 96 F250 4x4. I bought a module F3VF-15K602-AC. (was told this fits my truck). When I went to put it in there were no connectors to fit this module. Thanks
Old Feb 22, 2009 | 09:54 AM
71 F250 Sport Custom's Avatar
I just went and had a basic alarm with keyless entry, light flash and horn honk added by a car audio shop it was under $300. In the past I installed auto lock kits by hoffman. Is that a ford part ?
Old Feb 22, 2009 | 10:35 AM
geta4x4's Avatar
geta4x4
Yes, the part number is a Ford part number.
Old Feb 22, 2009 | 03:13 PM
BigBlueOx's Avatar
BigBlueOx
where did you look for the plugs? They should be right under the dash below where your right hand would be on the steering wheel, If that makes sense.
Old Feb 22, 2009 | 03:49 PM
geta4x4's Avatar
geta4x4
I have looked everywhere under the dash. There is a six pin female connecter with 3 wires (white/purple, grey/black, black) in the area you described. The connector on this module has a 26 pin male connector and a 16 pin male connector. Thanks
Old Feb 22, 2009 | 05:23 PM
Sportruk's Avatar
Sportruk
Unless the truck came from the factory with the Keyless Entry, the plugs are not there. It's a completely different dash wiring harness. Even the door locks are wired differently.
Old Feb 25, 2009 | 01:42 AM
geta4x4's Avatar
geta4x4
Thanks for the info. I guess I will have to do some wiring to get this to work. Does the antenna connector on the module go to the radio's antenna or does it have its own antenna for the remote FOB?
Old Apr 19, 2009 | 03:50 PM
BensTruck's Avatar
BensTruck
I Just bought a remote lock kit from LMC Truck. About $108 after shipping. The only problem, I think it was made for a truck without PL already installed. I'm having trouble installing the kit into the existing powerlock circuit. I would rather keep the power lock switches working if possible. But the wire diagram is kind of vague, so I'm not sure were to start splicing. Anyone else have experiance with this LMC kit?
2002exPSD
Feb 13, 2016 10:35 AM
conrod
Apr 18, 2015 09:41 PM
Soccer85
Apr 5, 2015 10:02 PM
dangerous_mechanic
20
Nov 17, 2014 08:03 AM
