AOD behind a 312ci in F 100
Old 02-21-2009, 06:42 PM
gusso's Avatar
gusso
gusso is offline
I think I have all the info I need on TV cables for the described hook up.
What I need is info on aftermarket shifter cables and hook ups.
I also am looking for any info you guys can give on brackets (etc.) for hooking up throttle cables and TV cables to a Edelbrock Carb.
By the way I have the original automatic steering column but will soon go with a Flaming River or Ididit column. Am eagerly awaiting any and all info
you guys and gals can offer. Thanks.
Gary
Old 02-21-2009, 07:13 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
Gary
Hi Gary,
If you're going to another column....is there anything wrong with yours and you want to sell it?
(is it a 53-56 column?)
Thanks,
Rick
Old 02-21-2009, 07:28 PM
gusso's Avatar
gusso
gusso is offline
Hey Rick,
Nothing wrong with it but it has been modified a bit to accommodate a Toyota PS box and still shift a Ford O Matic. It will be a while before I get a new column, If you want
it at a later date, I`ll make sure it`s available to you. Might want to PM me with a reminder. Thanks Rick. It`s a 1956.
Gary
Old 02-21-2009, 07:34 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Lokar is one source I can think of.
Old 02-21-2009, 11:31 PM
HT32BSX115's Avatar
HT32BSX115
Hey Rick,
Gary
Thanks,
Well, I want to use it in the F-600 of course and I want to shift an E4OD...
I think I'll have one more position than it will shift but I think it would still work. I just want a column in there that looks for the most part "stock" .......(of course , Ford never put an auto in a 55 F-600 .....minor detail )
Old 02-21-2009, 11:54 PM
gusso's Avatar
gusso
gusso is offline
Rick
I think the E4OD has thr gear detentes in the transmission. If so, a stock column could be modified (on shift plate under steering wheel) with a little filing, to make it work. I`m not an expert on E4OD`s, so I could be wrong about the detentes. Anyway good luck whichever way you go.
Gary
Old 02-22-2009, 12:01 AM
HT32BSX115's Avatar
HT32BSX115
Rick
Gary
Yes,
I believe you're right. It does have detents in the trans. The controller I have also has a provision for electronic shifting. (that ought'a be fun!!)
I also have a 2 speed axle That with the OD should be fun also!
I don't think the E4OD OD is as "tall" as the AOD OD though
Old 02-22-2009, 12:07 AM
gusso's Avatar
gusso
gusso is offline
Rick
For info:
The AOD overdrive is .67-1
Gary
Old 02-22-2009, 12:17 AM
HT32BSX115's Avatar
HT32BSX115
Yes I thought it was pretty tall. The E4OD is 0.71
With the 5.83:1 ratio axle I have and the 40" tires I expect about 2100 rpm at 60 mph ... It should run nice, empty down the highway....
By the way......that sure looks like an F-100 in your avatar (definitely NOT a Ford!)......coincidence?
Old 02-22-2009, 02:43 AM
gusso's Avatar
gusso
gusso is offline
It`s a Ford F-100 Super Sabre.
Gary
Old 02-22-2009, 02:48 AM
HT32BSX115's Avatar
HT32BSX115
Gary
Hmm,
All this time, I thought those were made by North American!
jmrayfordnut
11-18-2013 09:46 PM
Ryan Sigman
04-13-2013 11:49 PM
ZOOT
03-13-2013 02:08 PM
eanderson56
02-09-2009 12:00 PM
1Digger
03-21-2007 04:00 PM
Quick Reply: AOD behind a 312ci in F 100
