Yet another 6637 question....
"The maximum allowable restriction for a K&N Filtercharger is 15" of vacuum (water). If the restriction is allowed to go higher, the filter media might become so restricted that the element could distort allowing dirty air to bypass the filter and enter the engine."
As discussed in this thread ...Cold Air Intakes https://www.ford-trucks.com/forums/8...ml#post7095109 ...a very good filtration efficiency is required for removing particles that are 10 to 20 microns in size which do the most engine damage and my compressor wheel picture after only a few hundred miles of towing with a freshly oiled K&N demonstrates that at least my K&N wasn't up to the task of filtering these small size particles!
His misleading approach of averaging the under the hood temperatures between a colder ambient air location and a warmer one is the same as me claiming that my current life savings is the average of what I had a year ago and what I've got today! Not only that but he only took measurements while running around town empty!
Also the issue isn't about your maximum HP on a dyno run where the hood is usually open anyway and the engine compartment hasn't experienced a 2 hour "heat soak" due to towing grades on a hot summer day, but rather as I said in post #14 on this thread the real issue is that the hot intake air from under the hood is making your turbo work harder to flow more CFM to make the same HP because more CFM is needed to produce the same MAF to get the same HP because of the lower density of the hot under the hood air!
I think all those who currently use or plan to use a "6637" filter should considering the following.
The WIX 46637 is cross referenced to a Baldwin PA2818, and to a Donaldson B085011, however I doubt these three elements are of equal quality and more than likely the cheaper brands are of lesser quality and the maximum temperature rating for the highest quality Donaldson B085011 is already somewhat troubling!
The WIX site lists the WIX 46637 with a CFM:425 at the end of the spec list, but it doesn't give any "H20 vs CFM" restriction data.
Here's a link to the Donaldson site site...
http://www.donaldson.com/en/catalogs/engine/033621.pdf
... and it gives the following restriction data.
ECB Initial Airflow Restriction
CFM @ "H20 Air Cleaner
4"........6"........8 "......Model
280....400....470......B085011
On the Donaldson site the stated application for the B085011 filter is for gas and diesel engines in light to medium dust conditions. So this filter doesn't seem to be a good choice for the dusty conditions that many trucks encounter!
The Donaldson site also states that for the B085011 filter the temperature tolerance is 180 F continuous and to keep the filter away from the engine manifold and other very hot components because the DuraLite is only rated at 180 F maximum sustained temperature. I know for a fact that my F350 under the hood temperatures exceed 205 F on many occasions because that's the air temperature that causes the radiator fan clutch to lock up!
The Donaldson site also states to keep the filter away from battery acids, brake fluid, and other caustic fluids yet the in a 7.3L application the filter is mounted near the master cylinder and battery!
The Donaldson site recommends a 1.5" overlap and the use of a special Donaldson high torque hose clamp for their DuraLite air filters. I recall reading about problems with unfiltered air leaking in at the neck of these filters and sometimes the filters come completely disconnected from the intake tube!
The Donaldson site recommends to not judge the filter on the basis of a visual inspection but to use a restriction gauge that's located between the filter neck and the air intake to the engine. I've read many posts about how dirty should a 6637 get before it needs to be changed and most seem to have their restriction gauge located at the end of the filter where it can't sense the full filter restriction!
Here's why you need a restriction gauge that's mounted in the correct location... Heavy-Duty Diesel Engine Air Filter Collapse... http://www.filtercouncil.org/techdata/tsbs/06-2.htm ! If you get a leak in the up-pipes note that soot can plug an air filter rapidly and shorten the life of a filter dramatically, and if a restriction indicating device isn't monitored closely can result in extremely high pressure drop across the filter that may cause it to collapse.
I'm sure he'll tear me up on this, but I'm done arguing about it. I state my FACTS, he states umteen formulas and opinions, none of which changes the fact that on the dyno, the 6637 is an excellent performer, even with the hood down, and it filters just as well (per OAs) as any of the other good ones.
According to my data the stock filter is rated for a 260 CFM flow at a restriction of 4" H2O and from the Donaldson site the B085011 =? 6637 filter is rated for a 280 CFM flow at the same 4" H2O restriction which is only a 20 CFM higher flow at the same 4" H2O restriction and not the 165 CFM higher flow that's implied by your statement!
The reason I used an =? is because there's no guarantee that the cheaper WIX 46637 version actually flows as well as the Donaldson B085011? The WIX site lists the WIX 46637 with a CFM of 425 but it doesn't give an Inches H20 restriction at this 425 CFM flow and without knowing the Inches H20 restriction at a given CFM flow you really don't have any meaningful information at all!
Your statement also implies that a stock air filter can only flow a maximum of 260 CFM but at the RPM=2,600 and BP=17 psi for its maximum HP my computer model for a stock 99.5 version of a 7.3L indicates a MAF=Mass Air Flow lb/min of MAF=35 lb/min and a AFIVAF=Air Filter Inlet Volume Air Flow ft^3/min of AFIVAF=480 ft^3/min=480 CFM. So it seems to me that Ford must've designed the stock air filter to be able to handle a 480 CFM flow! Based on this it appears as though this statement from post #11 must be pretty close to being the truth after all...
Keep in mind that any filter will flow a higher CFM at a higher Inches H20 restriction! The issue is what's the maximum Inches H20 restriction that a filter can withstand before its supporting structure fails and allows it to collapse?
According to the caution on the K&N web site "The maximum allowable restriction for a K&N Filtercharger is 15" of vacuum (water). If the restriction is allowed to go higher, the filter media might become so restricted that the element could distort allowing dirty air to bypass the filter and enter the engine."
According to the quotes below a 6637 is also subject to collapse if it's operated at too high a restriction...
From post #8 here... https://www.ford-trucks.com/forums/6...7-testing.html ...
