I was wondering if anyone knew where I could get this lower dash trim (circled in red) and what it's called.
Also could someone post a side-view and head on pic of their ashtray opened with something for scale comparison (a dollar bill, etc.) I'm wanting to install a few 110V outlets in my truck and if it will fit in an ashtray I'll try to get one off ebay or junkyard.
That's a lower dash unit for a 2005-2007 PSD. sometimes you can find them on fleabay. Search as Ford or superduty lower dash or something creative like that. Ed would be also a great source for allocating it as well.
What switch/panel is that as well thats in the pocket area? And where can you get it? And can or what needs to be done to do this to a 2001 truck?
In the upper picture that is what Ford calls "upfitter switches" You'll need to add the 05 - 07 lower dash, then you can buy the upfitter switch with pigtails and wire up whatever you want.
Originally Posted by danskool
To add to the questions
What is that switch near your wallet? Bottom picture. Funny how dashes are ever so different among years.
That looks like the switch for an adjustable go pedal. Makes it slide forward or back.
Ahhhh nice!!! Any where in particular to get or order this lower dash panel? And the upfitter switch panel? And i assume its a direct bolt on ( the dash piece i am referring to)
Just looked at that pic. That a pretty badass setup as well. I know where to get the panel...but where do you get the switchs/panel i see in the pic? Can they be bought as a ford part or is that custom? Just need to decide which is more cost effective and easier.
Get in touch with Clay ar RiffRaff Diesel Performance. He is a supporting vendor here and can get you all the switches and the panel. Yes, it is a little bit of work getting the switches in and filling and sanding the rest of the panel, but It works.
TO THE O.P.
the 650 dash panel comes with a big hole where I mounted my switches, I did not make that clear in my first post. You could easily mount a couple of 110 plugs in there.
Here is a pic of the panel with the hole as it comes from FOMOCO
hey guys im brand new to this site, i was planning on installing a bull bar with fog lights and i didnt want to drill into my dash or anything so i figured id look into the 05 upfitter switches. i have a 04, i was also curious as to how much it would potentialy cost, how much modification, etc. id also like the one with the driver side glovebox if its any help. any info would be great.
