Cracked Exhaust Manifold
Are all of the ford exhaust manifolds as sorry as the ones on my truck? Both of mine are cracked and have to be replaced. I was just wondering if any of you have had to do this and where you got your new manifolds from? I've seen some on ebay. They range in price from $30 something to around $60 something. The higher priced ones claim to be stronger than the original OEM manifolds and want crack as easily. I would like to know where you guys recommend getting the manifolds from. I don't want to replace them but once.
Yes to both questions, Summit sells some good ones, just a straight across change over from stock manifolds.
I have the Summit shorties on my 351 and could not be more happy. They hook up to EGR rather nicely. They hook up to the factory y-pipe with no problems. I hooked mine up to the factory pipe and kept it that way a couple months before getting a custom made y-pipe that flows a lot better and really helped with performance. I have had no leaking problems, the flange is nice and thick, just make sure you use a good set of metal gaskets and not the garbage they come with. I know that some people have had problems with leaks at the collector where it meets up with the y-pipe. I put on two nuts on each bolt and hit them with red loctite. I have had no leaks. I have also had no problems with my spark plug wires, my Motorcraft wires have plenty of clearence. My other recomendation is make sure you have a piece of heat barrier over the computer as the headers cause higher underhood temperatures than manifolds.
P.S. there is no better time to get headers than when you have a leaky manifold. I had a manifold leaking and used this as my excuse with the wife for why I NEEDED to get headers.
Did you pull trailers with the truck in the past and overheat the manifolds??
Yeah, I wonder what's up with these damn things.
My '97 351W has a cracked driver's side manifold. Someone tried to replace it, but the rusted exhaust bolts stopped the jobber in the cold. One bolt was already broken off. Then someone patched the crack with some sorta white stuff.
Is there anybody who has improved the exhaust manifolds over factory? I don't want headers.
