Engine Missing/ Skipping
Old Feb 17, 2009 | 09:05 PM
Reid lariat's Avatar
Reid lariat
<!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start --><!-- In 1st Post Ad --><TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">A few weeks ago my engine started to lurch/skip/buck when I was traveling in overdrive at about 45 mph. As I would start up a slight incline and put a load on the engine the problem would start. I thought maybe a dirty air filter so I replaced it with a K and N drop in. Problem went away for about a week and then returned. Also I disengaged the O/D and the problem would still happen under a load on an incline. My mileage drop before the new airfilter by at least a mile per gallon. I have always gotten 14.9 MPG and now about 13.5 MPG. I know it is not alot but I have driven the truck for 2 1/2 years and always gotten the same mileage. Truck is a 2005 lariat with 82000 miles. I have an Edge set on level 2 that I never change. I would appreciate any input
Thanks Reid </TD></TR></TBODY></TABLE>
Old Feb 18, 2009 | 09:24 PM
Reid lariat
Bump. Anyone
Old Feb 19, 2009 | 07:11 AM
70f100longbed's Avatar
70f100longbed
Prob have a spark plug going bad. If you have access to a scan tool do a power balance test to find out which cylinder it is or you could look at Mode 6 data. I assume the CEL is not on b/c you didn't mention it. If it is on you will have a code for which cylinder too. Might be a good idea to do the whole set of plugs with 82k on the clock.
Old Feb 19, 2009 | 09:38 AM
DaMole's Avatar
DaMole
If it is throwing a code you should be able to check it with the Edge. It is under check for DTC's or something on the programmer. That would be the first thing to do.
cattlerancher
Jul 25, 2009 08:32 AM
Brooks Rowell
16
Apr 29, 2009 10:33 AM
quietman
Mar 7, 2009 09:36 PM
airshac
Bronco II
Feb 6, 2009 06:46 PM
MrNuckelhead
Jul 9, 2007 07:39 AM
