Aftermarket Products
Sponsored by: Worksport
spray in bedliners
Old Jan 11, 2002 | 09:47 PM
1967fordranger's Avatar
1967fordranger
spray in bedliners
I have a 67' f100 and I was considering putting spray in bed liner in it. I was wondering if they hold up good and if which one seems to be the best.
Old Jan 12, 2002 | 12:37 PM
StrangeRanger's Avatar
StrangeRanger
spray in bedliners
The urethane they use in the spray-in liners is extremely durable. I looked at several brands and chose Line-X. I liked both their process (I work in the urethane industry so I care about that sort of otherwise irrelevant stuff) and the non-slip texture of their liner better. Have them spray the rail caps as well, it's worth the extre $75 or so.
Old Jan 13, 2002 | 12:02 AM
chris112lee's Avatar
chris112lee
spray in bedliners
I have the true rhino liner. came with the truck when I bought it so I don't know how much it cost but, never scratched it. Toughest stuff I've ever seen. And the best part is that it keeps things from sliding unlike the plastic ones.
Old Jan 18, 2002 | 06:55 PM
Brian's Avatar
Brian
spray in bedliners
I had my buddies done by Speedliner. His is 4 years old and looks like new. He parks it outside in California so it sees a lot of UV. I'm getting my 66 longbed done next week. You have a choice of texture and color with Speedliner.
Old Jan 21, 2002 | 11:08 PM
Edmo's Avatar
Edmo
spray in bedliners
Getting a Line-X grey liner sprayed in tommorrow... Red F250 CC 4x4 with grey interior and grey bed rail covers... Should match up pretty nice.
Here in Anchorage, AK the Line-X runs $399 for my long box.
Edmo
Old Jan 24, 2002 | 01:08 PM
DrkPhanstm's Avatar
DrkPhanstm
spray in bedliners
OK, but how about the DIY spray in bedliners? I know Wal-Mart and most automotive stores i've seen sell it for ~$40 a gallon, enough to do a standard sized bed. $40 I can spring for if it will hold up respectably...
Old Feb 14, 2002 | 07:24 AM
Petrol's Avatar
Petrol
spray in bedliners
I highly recommend a spray in bedliner and think that the more common "slip-in" liners should not be considered by anyone. In fact I recommend new truck purchasers, when considering a truck from a dealer who has installed one as a "no cost dealer added bonus" have it and $250 removed from the truck after the best deal has been reached. You can then apply the $250 towards the cost of a "spray-on"
Yes these things are that good. We have all our company work trucks done by Line-X. We have people on staff that coat storage tank with liners but know that the pros can do a better (read appearance) job on the trucks.
As for the Do-IT-Yourself Kits. Leave them on the Wal-Mart shelves.
Unless, of course you don't care about the appearance of the job.
The pros have the EXPERIANCE, EQUIPMENT (spray and masking) as well as the ability to provide a warrenty.
It's well worth the $400-$700 a pro will charge (most will haggel)
Use of symbols or characters to mask profanity and expletives is
prohibited and undermines the spirit of these guidelines.
Petrol
99 XLT 5.4L
Old Feb 14, 2002 | 07:30 AM
Petrol's Avatar
Petrol
spray in bedliners
just a few more things to consider
just take a peek UNDER a "slid-in" plastic bed liner that has been installed for anything more then a few months. Check how they rub the paint right off the bed, trap dirt & water and encourage rust.
And think, it was bought to "Protect" the bed of the truck!
Petrol
99 XLT 5.4L
Old Feb 14, 2002 | 12:02 PM
Cope's Avatar
Cope
spray in bedliners
No doubt about it, they certainly do encourage rust. I sprayed mine when I got it two years ago and wouldn't consider anything else.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old Feb 14, 2002 | 12:42 PM
weldman's Avatar
weldman
Post spray in bedliners
[updated:LAST EDITED ON 14-Feb-02 AT 01:42 PM (EST)]I recomend ANY sprayed liner over the reg plastic ones. They make it quieter too!
Pendaliner is now making a flexible rubber type coated slip-in liner, but it will still trap water underneath.
My uncle had to cut a hole in his liner to fit a gooseneck in there. With the trailer on, the whole middle of the liner rises up from the wind!
Go rhino.
Old Feb 14, 2002 | 11:31 PM
khensley's Avatar
khensley
spray in bedliners
Posted this in the Superduty Forum:
I just had my rig done today with "Custom Lining". They supposedly use the exact same 50 gallon drums of stuff that Line-X uses. I paid $360 for mine. In researching beforehand, the local Line-X installer stated he used around 4 gallons per short bed....and doing all those little areas as described in a previous post are extra$$. Mine has all those done, plus over the top of the front edge of the bed. This was for $40 less than the quote I had for a BASIC LineX job. AND, they used 5 gallons of "goop".
I suspect the applications of each material vary from dealer to dealer...make sure they hand "scuff" the bed paint first, as it helps with adhesion of whatever brand liner material they use. Also, make sure they remove all bolts and hardware before the material application. I believe that's pretty standard now, but I've seen some where the hardware is covered...gotta destroy the liner to remove a bolt or tie-down bracket.
Kyle
Old Mar 11, 2002 | 11:04 PM
Edmo's Avatar
Edmo
spray in bedliners
<<<----- Photo of my Line-X Liner in my Gallery.
Edmo
Old Mar 28, 2002 | 07:12 PM
RE_SPEED_FAB's Avatar
RE_SPEED_FAB
spray in bedliners
Old Apr 3, 2002 | 06:58 PM
harryball's Avatar
harryball
spray in bedliners
I had a Dodge... I know... everybody calm down I got rid of it and got a Ford Anyway, I had a Line-X sprayed in it... I abused the ever loving bleep out of the thing. We're remodeling, I'd go to Home Depot and they'd sit a wooden pallet on the back and slide her in. I had to keep telling the lift drivers "don't worry, slide it in" It is almost indestructable.
My F350 got a Line-X at 2 days old.
Robert
Old Apr 3, 2002 | 07:00 PM
harryball's Avatar
harryball
spray in bedliners
One final comment, the installer makes all the difference. See their work before hand and try to talk to folks with a liner a year or two old. If they skimp on sanding the bed before application, it'll peal, if they skimp on thickness you can gouge through it.
Robert
keyspirate
6.7L Power Stroke Diesel
Aug 17, 2012 07:41 AM
christaylor
All Things Towing
Mar 21, 2011 04:54 AM
Bill in Bama
20
Jan 16, 2011 02:32 PM
Greywolf
Garage & Workshop
32
Aug 13, 2010 01:35 PM
tellico racing
Paint & Bodywork
Aug 29, 2005 12:35 AM
