grinding noise
Old Feb 16, 2009 | 12:30 AM
hare9371's Avatar
hare9371
grinding noise
hello,
I have a 2004 ford f150 xlt. I just replaced my brake pads and front left and back right calipers. After replacing this i went for a drive and there is now a new grinding noise. The grinding does not start until about 20MPH and only occurs when i am pushing the gas. the sound doesnt occur when i am going under 20 mph and doesnt work when i am breaking. Does anyone have any suggestions on what this could be?
Old Feb 18, 2009 | 09:18 PM
tazz3369's Avatar
tazz3369
grinding noise
i have a buddy with same problem mine as well shop figured it out it was the seal for vacum hub in the 4 wdrive or a post on here said check the iwe solenoid
Old Feb 23, 2009 | 10:05 AM
Reggie31's Avatar
Reggie31
I had this same problem after I replaced my front pads. I took it in and they said there was some safety clip or something rubbing and they put it back and it stopped. Shortly after I had sort of the same grinding noise come back and it ended up being bad bearings in the hub. Replaced the hub and have been noisefree for a few months now.
Old Feb 23, 2009 | 05:36 PM
tazz3369's Avatar
tazz3369
i have done both my front wheel bearings and it did not stop the grind that is what i thought as well but every repair job can be diff mne are just what happened to my truck for ref
Old Mar 10, 2009 | 06:16 PM
larrycmc's Avatar
larrycmc
i have an 06 a buddy checked with code reader. c-1979&c1980 came up.iwe solenoid needs replaced. mine would stop making noise when i switch to 4hi and cme back when i go to 2hi. they say the iwe gets wet and contaminates the vaccum to the hubs. the replacement part is of anew design.
Old Mar 14, 2009 | 10:41 AM
tazz3369's Avatar
tazz3369
yes i have picked up the update and i took of the front wheels started the truck up and the passenger side is free put the drivers side is locked up so my seal is leaking i also checked the vacum 20 lbs from the motor then it splits of to both front seals when i plugged the drivers side i had 20 at the passenger side when i hooked up the drivers side it dropped down to only ten and the new solenoid cost me 27 dollars cdn from ford
Old Mar 16, 2009 | 11:06 AM
bigun72's Avatar
bigun72
I have the same problem and mine didnt start till i put my 6" lift on last week , u can feel the floor vibrating a little.
Old Apr 20, 2009 | 08:03 PM
shaw22799's Avatar
shaw22799
Your vaccum solenoids are not working. You need to take it in and get them replaced. This was a warranty issue to where water would drain down the cowl and short out the solenoids. Ford has made the fix.
Old Apr 21, 2009 | 12:48 PM
slomafarms's Avatar
slomafarms
just last week i took my 04 screw in for a grinding noise from the frontend and both of the front hubs were bad and the motor on the tcase was goin out...so now i have new front hubs, iwe's, and that electric motor on the tcase
Old Apr 21, 2009 | 01:01 PM
Y2K350's Avatar
Y2K350
I had a smiliar problem only is was this high pitched shrieking/squeeking droning noise. I fixed it by pulling over to the side of the road and made my wife get out of the truck. All was quiet after that.
Old Apr 21, 2009 | 01:21 PM
double06's Avatar
double06
Classic! I can't believe I didn't think of that!
Old Apr 21, 2009 | 02:11 PM
slomafarms's Avatar
slomafarms
HAHAHA good one!!!!
mblanken881
Sep 24, 2013 06:25 PM
joboblund
2004 - 2008 F150
Apr 19, 2007 07:27 PM
AvalancheChaser
1978 - 1996 Big Bronco
Apr 3, 2006 03:44 PM
99F-250lova
Feb 28, 2006 04:05 PM
